Installation & Licensing
Revit 2014 deployment error 1619 help
1 REPLY 1
jason.quarry
761 Views, 1 Reply
Here is my log file. Can anyone help me determine why this deployment will not work on some machines but not others? Autodesk has been added to trusted sites and TEMP folders have been emptied. Thanks for your help.
2013/10/29:10:54:35 byce 1208KALP === Setup started on 1208KALP by byce ===
2013/10/29:10:54:35 byce 1208KALP Path_Length: 149
2013/10/29:10:54:35 byce 1208KALP Current Directory \\0709KBNAS\Shared\Program Files\AutoDesk Install\Deployment\Img
2013/10/29:10:54:35 byce 1208KALP Launch
2013/10/29:10:54:35 byce 1208KALP CommandLine /qb /I \\0709KBNAS\Shared\Program Files\AutoDesk Install\Deployment\Img\Master Premium.ini /language en-us
2013/10/29:10:54:37 byce 1208KALP Path_Length: 149
2013/10/29:10:54:37 byce 1208KALP Current Directory C:\Users\BYCE~1.BYC\AppData\Local\Temp\_AICA81.tmp
2013/10/29:11:09:29 byce 1208KALP === Setup ended ===
2013/10/29:10:57:41 byce 1208KALP === Setup started on 1208KALP by byce ===
2013/10/29:10:57:41 byce 1208KALP Path_Length: 149
2013/10/29:10:57:41 byce 1208KALP Current Directory C:\Users\BYCE~1.BYC\AppData\Local\Temp\_AICA81.tmp
2013/10/29:10:57:41 byce 1208KALP Launch
2013/10/29:10:57:48 byce 1208KALP Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\BYCE~1.BYC\AppData\Local\Temp\_AICA81.tmp\Setup\RevitSetup.dll
2013/10/29:10:57:48 byce 1208KALP Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/10/29:11:06:37 byce 1208KALP Installing DirectX® Runtime: "\\0709KBNAS\Shared\Program Files\AutoDesk Install\Deployment\Img\3rdParty\DirectX\DXSETUP.exe" /silent
2013/10/29:11:26:08 byce 1208KALP Install DirectX® Runtime Succeeded
2013/10/29:11:26:35 byce 1208KALP Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® Building Design Suite Premium 2014" SETUP_PACKAGECODE={D7E74739-DCD0-48e4-86A5-6203809C3639} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="\\0709KBNAS\Shared\Program Files\AutoDesk Install\Deployment\Img\" ADLM_EULA_COUNTRY=US FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/10/29:11:27:34 byce 1208KALP Install FaroSDK Succeeded
2013/10/29:11:27:34 byce 1208KALP Installing Autodesk® Revit® 2014: TRANSFORMS="\\0709KBNAS\Shared\Program Files\AutoDesk Install\Deployment\Img\x64\en-us\RVT2014\RVT2014.mst;\\0709KBNAS\Shared\Program Files\AutoDesk Install\Deployment\Img\x64\RVT2014\RVT2014-Master Premium.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® Building Design Suite Premium 2014" SETUP_PACKAGECODE={D7E74739-DCD0-48e4-86A5-6203809C3639} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=",Internet Explorer 7,SSE2 Support Check,Microsoft Visual C++ 2008 SP1 Redistributable (x64),Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161,Microsoft Visual C++ 2005 Redistributable (x86),Microsoft Visual C++ 2005 Redistributable (x64),Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161,Microsoft Visual C++ 2010 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x64),{04B34E21-5BEE-3D2B-8D3D-E3E80D253F64},{B42E259C-E4D4-37F1-A1B2-EB9C4FC5A04D},{14866AAD-1F23-39AC-A62B-7091ED1ADE64},{4B90093A-5D9C-3956-8ABB-95848BE6EFAD},{C3A57BB3-9AA6-3F6F-9395-6C062BDD5FC4},{6DA2B636-698A-3294-BF4A-B5E11B238CDD},{F6F09DD8-F39B-3A16-ADB9-C9E6B56903F9},{8CCEA24C-51AE-3B71-9092-7D0C44DDA2DF},Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86),Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64),.NET Framework Runtime 3.5 SP1,.NET Framework Runtime 4.5,.NET Framework Runtime 4.5 Language pack,DirectX® Runtime,{8A470330-70B2-49AD-86AF-79885EF9898A},;{11672AB2-3D48-4D38-9123-719E5FF93333},{644F9B19-A462-499C-BF4D-300ABC2A28B1},{51BF3210-B825-4092-8E0D-66D689916E02},{5C29CC1F-218F-4C30-948A-11066CAC59FB},;;" ADSK_SOURCE_ROOT="\\0709KBNAS\Shared\Program Files\AutoDesk Install\Deployment\Img\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/10/29:12:47:44 byce 1208KALP Install Autodesk® Revit® 2014 Succeeded
2013/10/29:12:47:50 byce 1208KALP Installing Autodesk® Revit® 2014 Language Pack: TRANSFORMS="C:\Users\BYCE~1.BYC\AppData\Local\Temp\_AICA81.tmp\_la716E.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® Building Design Suite Premium 2014" SETUP_PACKAGECODE={D7E74739-DCD0-48e4-86A5-6203809C3639} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" MUIHIDEARP=1 ADSK_SOURCE_ROOT="\\0709KBNAS\Shared\Program Files\AutoDesk Install\Deployment\Img\" ADLM_EULA_COUNTRY=US INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/10/29:12:47:52 byce 1208KALP Install Autodesk® Revit® 2014 Language Pack Failed Installation aborted, Result=1603
2013/10/29:12:51:07 byce 1208KALP Rollback Autodesk® Revit® 2014 Succeeded
2013/10/29:12:51:09 byce 1208KALP Rollback FaroSDK Succeeded
2013/10/29:12:51:09 byce 1208KALP Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2013/10/29:13:04:05 byce 1208KALP === Setup ended ===
1 REPLY 1
brad_hurley
in reply to: jason.quarry
Hello Jason,
Thank you for contacting the community.  I can see from your log that you are getting two types of error messages. These errors are:
“Install Autodesk® Revit® 2014 Language Pack Failed Installation aborted, Result=1603”
And
“Rollback DirectX® Runtime Failed Failure is ignored, Result=1619”
The 1603 error is a generic error code created by MS Windows Installer (MSI).   There are a bunch of causes and solutions to resolve these types of errors, such as:
  • File is locked and cannot be overwritten.
  • Windows Temp folders are full.
  • Not enough disk space
  • Setup files were corrupted during extraction.
  • Short file name creation is disabled on target machine.
  • Insufficient Access
For more details please refer to the following links:
Error 1603 during silent installation from network deployment
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=10310469&linkID=9240617
Error 1603 during installation of Autodesk software
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22132908&linkID=12305695
You receive an "error 1603: A fatal error occurred during installation" error message when you try to install a Windows Installer package
http://support.microsoft.com/kb/834484/en-us
The 1619 error code is another Microsoft error.  This is an indication that the install package cannot be opened.
System Error Codes (1300 – 1699)
http://msdn.microsoft.com/en-us/library/windows/desktop/ms681385%28v=vs.85%29.aspx
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
BHurley
Autodesk, Inc.
Administrator Productivity
