Installation & Licensing
Revit 2014 Architecture Issue
2 REPLIES 2
212 Views, 2 Replies
I downloaded Revit 2014 the other day and I've got a question about how to open an architectural project.
When I try and open a New Project the only option that I have is to Open from a Structural Template.  I brose to the US Imperial Folder and that is the only file that is in the folder.
Did I mess up something in the download as to why I cant open an Architectural Template or do I need to create one some how?
Even if I open the Structural Template it says Failed to Open when I hit OK and try and load a new project.
Let me know if there are any solutions to this issue.
THX
2 REPLIES 2
pendean
When you installed REVIT 2014, did you select ARCHITECTURE or CONSTRUCTION at the start of the process?
When I click on NEW on the REVIT startup screen under PROJECTS, I can select from a pulldown or Architecture or Construction Template, or browse my own for example. Can you post a screenshot of your REVIT startup screen and what happens after youo do the same as above?
in reply to: pendean
I don't think I had the option. Should I uninstall and reinstall Revit?
Sent from my iPhone
Administrator Productivity
