I have gotten most of the way through the installation of Revit 2014, but it wont let me press install on the menu. I have previously installed Revit on this computer, but had to delete when I cleared my hard drive. So everything should go smoothly, but I still get the issue after many restarts.
This image shows the issue:
Hey mam,srry bt i am facing a little bit same trouble, my install option is ready to be used bt when i try to install it ,it only installs the exchange app program instead of full application as it is showing 0 bytes required .Pls reply asap.
The original poster was trying to install Autodesk Revit.. Are you trying to do that or install AutoCAD? If AutoCAD, in the future create your own posting/problem and not reply to a totally different subject matter.
Now to your problem.. Are you saying you are trying to install AutoCAD? Its already installed? Does it work?
Mark Lancaster
& Autodesk Services MarketPlace Provider
While I am trying to install Autodesk Autocad civil 3D 2013 on my laptop. It gives an error 0 bytes req: (Please refer image).
How can i solve this problem.
There's no need to post multiple times.. You only need to post once.
Mark Lancaster
