Installation & Licensing
REVIT 2013 won't open on Laptop
10 REPLIES 10
Message 1 of 11
JulieDeZeeuw2461
5808 Views, 10 Replies
I've just received my new 2013 Building Design Suite and all has loaded fine on my laptop except for REVIT.  When I try to open the program it freezes within 5 seconds and displays a message saying "Autodesk REVIT has stopped working. A problem caused the program to stop working properly..."  Is this a hardware problem or Autodesk Software problem?
Many thanks
10 REPLIES 10
Message 2 of 11
Try logging in as another user with local admin rights and launching it.
Autodesk Forums:
Message 3 of 11
Unfortunately logging in as another user hasn't worked.
I have also repaired the REVIT installation but this made no difference.
It will now not let me uninstall/change at all. Nothing happens when I try via the control panel programs.
So what now?
Message 4 of 11
Try starting Revit again, then check the Windows Event Viewer, Windows Logs, Applications for Errors or Warnings at the time you tried to start Revit.
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
Message 5 of 11
To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
http://support.microsoft.com/mats/Program_Install_and_Uninstall
For more information on the Autodesk KB Support article concerning the clean uninstall of Autodesk products, see this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
For all other installation problems on Windows XP SP2 or below consider using the Microsoft Installer Clean Up Utility. For more information on this program, please my forum post here:
http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Installer-Clean-Up-Utility-for-Add-Re...
Autodesk Forums:
Message 6 of 11
Thank you so much, Travis, the uninstall worked, the reinstall went smoothly and we are up and running! HOORAY!
THANK YOU for your help!!!!
Message 7 of 11
in reply to: TravisNave
i have a proble on opening 2013 revit suddenly stopp working and the message that pop up is
"autodesk revit has stopped working
a problem caused the program to stop working correctly.
windows will close the program and notify you if solution is available"
please hep me to restoure the program
i try all the steps sugested and still didnt work what should i do
Message 8 of 11
birznieks_ingus
I have the same problem! I did everything, but REVIT still doesn't work!!!
Message 9 of 11
cisco5900
in reply to: birznieks_ingus
I also had this happen a few days ago and have not successfully found a solution. Revit was installed and working fine, then stopped working and will not restart, even after a clean uninstall.
Message 10 of 11
Edgaras.BIM.old
in reply to: cisco5900
I have the same problem with Revit 2014
Message 11 of 11
in reply to: JulieDeZeeuw2461
The problem will be solved after updating the driver for your graphics card. The very important point is that you shouldn't get the latest driver from your laptop manufacturer. Instead, you should visit the website of the manufacturer of your graphics card. I had the same issue with Revit 2013. I had an XPS Dell L502X laptop and my graphics card is NVIDIA GeForce GT 525M. I downloaded the driver from DELL website and the problem didn't solve. I did everything to solve the problem, installing a fresh windows, changing the windows form 64 bit version to 32 bit version, trying other versions of Revit, installing the latest service pack for Revit, removing app data,..., but none of them could solve the problem. Finally I found out that the driver provided by DELL is NOT the latest version! After downloading the latest driver from the website of NVIDIA, the problem solved completely.
Administrator Productivity
