Installation & Licensing
New Member
hpp24
Message 1 of 8 (3,662 Views)
Revit 2013 Product Key Failure
3662 Views, 7 Replies
08-15-2012 07:18 AM
The product key for Revit 2013 is incorrect.  It is for Revit Architecture 2013 that no longer exists and does not work for Revit 2013.  I've tried other keys from the product key list on the web, and they don not work either.  What is the product key for Revit 2013?  Thank-you.
either 765E1 (building suite premium) or 766E1 (building suite ultimate) depending on what suite your installing
Revit 2013 is only available in the building suites
DarrenP
Message 2 of 8 (3,656 Views)
Re: Revit 2013 Product Key Failure
08-15-2012 07:51 AM in reply to: hpp24
New Member
hpp24
Message 3 of 8 (3,651 Views)
08-15-2012 08:15 AM in reply to: DarrenP
That worked.  Thank-you very much.
TravisNave
Message 4 of 8 (3,647 Views)
08-15-2012 08:23 AM in reply to: hpp24
Make sure you mark Darren as the accepted solution and/or give him Kudos.  He's an excellent resource around here and deserves every recognition.  :smileywink:
New Member
maggs6
Message 5 of 8 (1,690 Views)
11-07-2013 02:33 AM in reply to: DarrenP
hey darren i just used that key recently for a program that my dad needs and once i enter the code and open the program when i try and activate it, it comes up with error code 110 how can i resolve this?
t_gaisf
Message 6 of 8 (1,685 Views)
11-07-2013 03:31 AM in reply to: maggs6
You can find all the product keys on our website.
If this does not solve the issue please send me a PM (click on t_gaisf profile name and then Send this User a Private Message) with your Serial Number, the request code if available and confirm the registered company name
or contact our licence assistance team for direct support.
Regards
Franz Gaisbauer
New Member
maggs6
Message 7 of 8 (1,671 Views)
11-07-2013 01:29 PM in reply to: hpp24
thanks for the feedback but i had already tried using the code from ur website  for autodesk revit 2013 structure. Once everything is installed and i try and activate my product it tells me to type in my serial number again like i did to download the product but this time it tells me that the serial number is invalid. I have tried for 3 days straight trying everything i can like re-downloading trying different codes researching problems and still no solution.
Customer Service
mike.beale
Message 8 of 8 (1,659 Views)
11-07-2013 02:27 PM in reply to: maggs6
Hi Tyrone!
Typically a serial number will show as not valid when it has been upgraded to a newer version, usually due to it being attached to an expired subscription.
Please Private Message me the serial number or contact our License Assistance Team for direct validation.
Thank you for contributing to our online community!
Mike Beale
