Installation & Licensing
0 Kudos
Post 11 of 14
Re: Revit 2013, no Templates or Libraries installed
10-01-2012 01:18 PM in reply to: kheaver
best advice, thank you, took 3 passes the rfa's appeared on pass #2, the rte's finally arrived on pass #3.  now the only problem is that I installed from a download to my download directory and it sits there.  so, is it safe to delete, did it install everything it needed to everywhere else, or is it a doppelganger for life, permanently resident in the downloads of life?
Active Member
0 Kudos
Post 12 of 14
Re : Revit 2013, no Templates or Libraries installed
10-21-2012 04:11 PM in reply to: kheaver
you will find what you need in my blog and after all what you need to do is to extract the files in the correct paths
http://faycaloudjhih.blogspot.com/2012/08/revit-structure-templates-families.html
Good Luck
Oudjhih Fayçal
New Member
0 Kudos
Post 13 of 14
01-28-2013 09:51 AM in reply to: kheaver
It woks Thank you
New Member
0 Kudos
Post 14 of 14
06-13-2014 01:03 PM in reply to: germanaoa
I do all the steps with add contents, but in the process i get this message "The feature you are trying to use is on a network resource that is unavailable".. what to do please explain.. its urgent .. i lost two days in trying to get this library..
i also tried with putting old library from friend to c/program data/autodesk/rac213/family templates.. but its not working too..
