Installation & Licensing
Revit 2013 - Microsoft Visual C++ 2005 Redistributable (x86)Failed
4 REPLIES 4
flowwi3dizzi3
2808 Views, 4 Replies
Hye,
I have encounter this problem during Revit 2013 Installation. Im currently running on Window 7 Home Premium, Intel Core i7 - 3610QM 2.30GHz, 8.00 GB RAM with 64-bit OS.
Ive tried to uninstall  all MV C++ 2005 Redistributable Package but still Revit keep on failing. I hope AUTODESK would help and guide me through this hassle.
2013/4/28:11:07:47    fLoWwi3    FLOWWI3-PC    === Setup started on FLOWWI3-PC by fLoWwi3 ===
2013/4/28:11:07:47    fLoWwi3    FLOWWI3-PC    Launch
2013/4/28:11:07:47    fLoWwi3    FLOWWI3-PC    CommandLine    /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/Autodesk_Revit_2013_English_Win_32_64bit_w..." /SN 900-29883822 /PK 829E1 /student /skipEULA /akamai /auth  /sid
2013/4/28:11:08:33    fLoWwi3    FLOWWI3-PC    === Setup ended ===
2013/4/28:11:07:48    fLoWwi3    FLOWWI3-PC    === Setup started on FLOWWI3-PC by fLoWwi3 ===
2013/4/28:11:07:48    fLoWwi3    FLOWWI3-PC    Launch
2013/4/28:11:08:33    fLoWwi3    FLOWWI3-PC    Download    Skipped    SETUP_CONFIG    http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/SET...
2013/4/28:11:08:33    fLoWwi3    FLOWWI3-PC    PageOpen    LaunchDialog
2013/4/28:11:09:22    fLoWwi3    FLOWWI3-PC    PageOpen    LicenseDialog
2013/4/28:11:09:22    fLoWwi3    FLOWWI3-PC    PageOpen    ProductInfoDialog
2013/4/28:11:09:22    fLoWwi3    FLOWWI3-PC    PageOpen    ProductSelectionDialog2
2013/4/28:11:09:32    fLoWwi3    FLOWWI3-PC    PageOpen    FullProgressDialog
2013/4/28:11:09:32    fLoWwi3    FLOWWI3-PC    Download    Skipped    VCREDIST2005X86    http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR...
2013/4/28:11:09:32    fLoWwi3    FLOWWI3-PC    Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\fLoWwi3\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/4/28:11:09:44    fLoWwi3    FLOWWI3-PC    Install    Microsoft Visual C++ 2005 Redistributable (x86)    Failed    Installation aborted, Result=1603
Thanks for reading
-flowwie-
4 REPLIES 4
abe
in reply to: flowwi3dizzi3
I'm having the same problem as you. No one replied to you. Did you solve it? I'm trying to re-install 2012 on a machine that I just put a new HD and OS in.
I'm going to try downloading from Microsoft directly and install: http://www.microsoft.com/en-us/download/details.aspx?id=21254
Abe Degnan
I've been a Revit user since version 1.x circa 1999, but I'm not a full-time user in my daily job.
www.degnandesignbuilders.com
TravisNave
in reply to: abe
Welcome to the community, abe.
That should work out for you.
Your product is failing to install because the prerequiste program required by the installer is failing prior to the installation of your Autodesk software.
If the prerequisite program already exists on your computer, it is likely newer than the one the Autodesk installer is attempting to install. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
The prerequisite is not already installed and installation still fails, then you may need to make an advanced edit to the setup.ini file to ignore the error. Please make sure you manually install the prerequisite file from Microsoft and then modify the setup.ini file accordingly.
For more information on this process, please see my KB article here:
http://forums.autodesk.com/t5/Installation-Licensing/Install-NET-Framework-Language-Pack-Failed-Inst...
Autodesk Forums:
flowwi3dizzi3
in reply to: abe
I do have the same problem but manage to solve it in a very2 looonnggg process. first of all u need to check on Viruses and Malware located in ur PC. this will block certain updates in the Windows which put ur PC in old / outdated windows update.. remove all the viruses / malware...I hope ur with me with this kind of explaination......
2nd u need to update ur windows expecially the Visual C++. from this point on i hope u will manage to install the software and if...... it is still the same, u need to explore ur Command promp function in Windows.
3rd, U type in CMD in the search function in the start up button and right click on it.. RUN AS ADMIN and click ok.use the command chkdsk /r /f
abe
in reply to: TravisNave
I ended up installing Revit but NOT the DWG Review. That did solve my problem but I don't have DWG review either.
Abe Degnan
Administrator Productivity
