Installation & Licensing
Revit 2013 LT won't install
1 REPLY 1
206 Views, 1 Reply
We are installing Revit 2013 LT.
There is quite some other Autocad software installed on this workstation. Inluding Revit 2015?
I'm in doubt if this could be the issue why the setup won't run.
Just nothing happens when we are running the setup. The installation is fully downloaded from the Autocad website.
No loggings, no event log errors, turned off the firewall and virusscanner, cleaned the temp folder, Windows is up to date.
OS: Windows 7.
Thanks in advance.
1 REPLY 1
dembkod
Com4automatisering
Hello. First make sure you have the installer downloaded. Download the installer completely from here:
http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
After this, run the program. If it still fails try the following:
-Update your graphics card driver (yes this could seriously work)
-Uninstall Microsoft NET
-Uninstall the Microsoft C++ redistributables
Now run the installer.
Thank you for taking part in our community!
David Dembkoski
Administrator Productivity
