I unistalled and re-installed Bldg. Design Suite 2013 recently after it became inoperable. Now, all programs were reintalled and launched except Revit. (Refer to error message). The desktop shortcut error message is: "Problem with Shortcut" The item 'Revit.exe' that this shortcut refers to has been changed or moved, so this shortcut will no longer work properly.
HELP!!!
Looks like it is trying to launch the installer extraction for the remaining parts. If your product is installed, then you can just launch it from start, or recreate your shortcut from there. Otherwise, if it still needs to be installed, then I suggest you redownload the product if you are missing the install files.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21889745&linkID=9240617
