Installation & Licensing
Revit 2013 Installation Issue
1 REPLY 1
265 Views, 1 Reply
I am unable to install Revit 2013 onto my 32 Bit Windows 7 computer. The following is the installation log report, any help/suggestions would be much appreciated.
2013/3/11:14:05:10 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/3/11:14:05:10 Brendan MATT-PC Launch 2013/3/11:14:05:35 Brendan MATT-PC === Setup ended ===
2013/3/11:14:05:16 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/3/11:14:05:16 Brendan MATT-PC Launch 2013/3/11:14:05:36 Brendan MATT-PC === Setup ended ===
2013/3/11:14:07:38 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/3/11:14:07:38 Brendan MATT-PC Launch 2013/3/11:14:07:58 Brendan MATT-PC === Setup ended ===
2013/3/11:14:07:43 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/3/11:14:07:43 Brendan MATT-PC Launch 2013/3/11:14:07:59 Brendan MATT-PC === Setup ended ===
2013/3/11:14:26:16 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/3/11:14:26:16 Brendan MATT-PC Launch 2013/3/11:14:26:24 Brendan MATT-PC === Setup ended ===
2013/3/11:14:26:20 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/3/11:14:26:20 Brendan MATT-PC Launch 2013/3/11:14:26:25 Brendan MATT-PC === Setup ended ===
2013/3/11:14:29:36 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/3/11:14:29:36 Brendan MATT-PC Launch 2013/3/11:14:30:15 Brendan MATT-PC === Setup ended ===
2013/3/11:14:29:42 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/3/11:14:29:42 Brendan MATT-PC Launch 2013/3/11:14:30:14 Brendan MATT-PC Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message: 2013/3/11:14:30:15 Brendan MATT-PC PageOpen LaunchDialog   2013/3/11:14:30:18 Brendan MATT-PC PageOpen LicenseDialog   2013/3/11:14:30:25 Brendan MATT-PC PageOpen ProductInfoDialog   2013/3/11:14:46:03 Brendan MATT-PC === Setup ended ===
2013/3/11:14:55:12 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/3/11:14:55:12 Brendan MATT-PC Launch 2013/3/11:14:55:51 Brendan MATT-PC === Setup ended ===
2013/3/11:14:55:16 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/3/11:14:55:16 Brendan MATT-PC Launch 2013/3/11:14:55:50 Brendan MATT-PC Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message: 2013/3/11:14:55:51 Brendan MATT-PC PageOpen LaunchDialog   2013/3/11:14:55:53 Brendan MATT-PC PageOpen LicenseDialog   2013/3/11:14:56:00 Brendan MATT-PC PageOpen ProductInfoDialog   2013/3/11:15:01:46 Brendan MATT-PC PageOpen ProductSelectionDialog2   2013/3/11:15:06:09 Brendan MATT-PC PageOpen FullProgressDialog   2013/3/11:15:06:09 Brendan MATT-PC Installing DirectX® Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent 2013/3/11:15:07:37 Brendan MATT-PC Install DirectX® Runtime Succeeded  2013/3/11:15:07:37 Brendan MATT-PC Installing FaroSDK: E:\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT 2013/3/11:15:07:42 Brendan MATT-PC Install FaroSDK Succeeded  2013/3/11:15:07:44 Brendan MATT-PC Installing Autodesk® Revit® 2013:  TRANSFORMS="E:\x86\en-us\RVT2013\RVT2013.mst;C:\Users\Brendan\AppData\Local\Temp\_AI87DE.tmp\x86\RVT2013\RVT2013-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="E:\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/11:15:07:44 Brendan MATT-PC Install Autodesk® Revit® 2013 Failed Installation aborted, Result=1618 2013/3/11:15:07:44 Brendan MATT-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1618 2013/3/11:15:07:50 Brendan MATT-PC PageOpen InstallCompleteDialog   2013/3/11:15:08:59 Brendan MATT-PC === Setup ended ===
2013/3/11:15:09:01 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/3/11:15:09:01 Brendan MATT-PC Launch 2013/3/11:15:09:34 Brendan MATT-PC === Setup ended ===
2013/3/11:15:09:04 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/3/11:15:09:04 Brendan MATT-PC Launch 2013/3/11:15:09:33 Brendan MATT-PC Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message: 2013/3/11:15:09:34 Brendan MATT-PC PageOpen LaunchDialog   2013/3/11:15:09:39 Brendan MATT-PC PageOpen LicenseDialog   2013/3/11:15:09:49 Brendan MATT-PC PageOpen ProductInfoDialog   2013/3/11:15:14:59 Brendan MATT-PC PageOpen ProductSelectionDialog2   2013/3/11:15:16:32 Brendan MATT-PC PageOpen FullProgressDialog   2013/3/11:15:16:33 Brendan MATT-PC Installing DirectX® Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent 2013/3/11:15:18:47 Brendan MATT-PC Install DirectX® Runtime Succeeded  2013/3/11:15:18:47 Brendan MATT-PC Installing FaroSDK: E:\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT 2013/3/11:15:18:55 Brendan MATT-PC Install FaroSDK Succeeded  2013/3/11:15:18:57 Brendan MATT-PC Installing Autodesk® Revit® 2013:  TRANSFORMS="E:\x86\en-us\RVT2013\RVT2013.mst;C:\Users\Brendan\AppData\Local\Temp\_AI3644.tmp\x86\RVT2013\RVT2013-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="E:\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/11:15:31:10 Brendan MATT-PC Install Autodesk® Revit® 2013 Failed Installation aborted, Result=1603 2013/3/11:15:31:11 Brendan MATT-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2013/3/11:15:31:13 Brendan MATT-PC PageOpen InstallCompleteDialog   2013/3/11:15:31:46 Brendan MATT-PC === Setup ended ===
2013/3/28:12:13:13 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/3/28:12:13:13 Brendan MATT-PC Launch 2013/3/28:12:13:32 Brendan MATT-PC === Setup ended ===
2013/3/28:12:13:17 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/3/28:12:13:17 Brendan MATT-PC Launch 2013/3/28:12:13:32 Brendan MATT-PC Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message: 2013/3/28:12:13:32 Brendan MATT-PC PageOpen LaunchDialog   2013/3/28:12:13:36 Brendan MATT-PC PageOpen LicenseDialog   2013/3/28:12:13:39 Brendan MATT-PC PageOpen ProductInfoDialog   2013/3/28:12:16:25 Brendan MATT-PC PageOpen ProductSelectionDialog2   2013/3/28:12:17:45 Brendan MATT-PC PageOpen FullProgressDialog   2013/3/28:12:17:45 Brendan MATT-PC Installing DirectX® Runtime: C:\Users\Brendan\Desktop\Auocad\3rdParty\DirectX\DXSETUP.exe /silent 2013/3/28:12:18:37 Brendan MATT-PC Install DirectX® Runtime Succeeded  2013/3/28:12:18:37 Brendan MATT-PC Installing FaroSDK: C:\Users\Brendan\Desktop\Auocad\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT 2013/3/28:12:18:45 Brendan MATT-PC Install FaroSDK Succeeded  2013/3/28:12:18:46 Brendan MATT-PC Installing Autodesk® Revit® 2013:  TRANSFORMS="C:\Users\Brendan\Desktop\Auocad\x86\en-us\RVT2013\RVT2013.mst;C:\Users\Brendan\AppData\Local\Temp\_AICEF9.tmp\x86\RVT2013\RVT2013-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\Brendan\Desktop\Auocad\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/28:12:33:40 Brendan MATT-PC Install Autodesk® Revit® 2013 Failed Installation aborted, Result=1603 2013/3/28:12:33:41 Brendan MATT-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2013/3/28:12:33:44 Brendan MATT-PC PageOpen InstallCompleteDialog   2013/3/28:13:17:49 Brendan MATT-PC === Setup ended ===
2013/4/4:09:01:51 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/4/4:09:01:51 Brendan MATT-PC Launch 2013/4/4:09:02:11 Brendan MATT-PC === Setup ended ===
2013/4/4:09:02:36 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/4/4:09:02:36 Brendan MATT-PC Launch 2013/4/4:09:02:50 Brendan MATT-PC === Setup ended ===
2013/4/4:09:02:46 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/4/4:09:02:46 Brendan MATT-PC Launch 2013/4/4:09:02:50 Brendan MATT-PC === Setup ended ===
2013/4/4:09:02:59 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/4/4:09:02:59 Brendan MATT-PC Launch 2013/4/4:09:03:09 Brendan MATT-PC === Setup ended ===
2013/4/4:09:03:04 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/4/4:09:03:04 Brendan MATT-PC Launch 2013/4/4:09:03:04 Brendan MATT-PC [Error: 1052] The requested control is not valid for this service. 2013/4/4:09:03:10 Brendan MATT-PC === Setup ended ===
2013/4/4:09:03:19 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/4/4:09:03:19 Brendan MATT-PC Launch 2013/4/4:09:03:24 Brendan MATT-PC === Setup ended ===
2013/4/4:09:03:22 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/4/4:09:03:22 Brendan MATT-PC Launch 2013/4/4:09:03:25 Brendan MATT-PC === Setup ended ===
2013/4/4:09:03:26 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/4/4:09:03:26 Brendan MATT-PC Launch 2013/4/4:09:03:35 Brendan MATT-PC === Setup ended ===
2013/4/4:09:03:31 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/4/4:09:03:31 Brendan MATT-PC Launch 2013/4/4:09:03:36 Brendan MATT-PC === Setup ended ===
2013/4/4:09:03:41 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/4/4:09:03:41 Brendan MATT-PC Launch 2013/4/4:09:04:03 Brendan MATT-PC === Setup ended ===
2013/4/4:09:03:44 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/4/4:09:03:44 Brendan MATT-PC Launch 2013/4/4:09:04:02 Brendan MATT-PC Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message: 2013/4/4:09:04:03 Brendan MATT-PC PageOpen LaunchDialog   2013/4/4:09:04:05 Brendan MATT-PC PageOpen LicenseDialog   2013/4/4:09:04:10 Brendan MATT-PC PageOpen ProductInfoDialog   2013/4/4:09:08:45 Brendan MATT-PC PageOpen ProductSelectionDialog2   2013/4/4:09:09:03 Brendan MATT-PC PageOpen FullProgressDialog   2013/4/4:09:09:03 Brendan MATT-PC Installing DirectX® Runtime: C:\Users\Brendan\Desktop\Auocad\3rdParty\DirectX\DXSETUP.exe /silent 2013/4/4:09:10:18 Brendan MATT-PC Install DirectX® Runtime Succeeded  2013/4/4:09:10:18 Brendan MATT-PC Installing FaroSDK: C:\Users\Brendan\Desktop\Auocad\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT 2013/4/4:09:10:26 Brendan MATT-PC Install FaroSDK Succeeded  2013/4/4:09:10:26 Brendan MATT-PC Installing Autodesk® Revit® 2013:  TRANSFORMS="C:\Users\Brendan\Desktop\Auocad\x86\en-us\RVT2013\RVT2013.mst;C:\Users\Brendan\AppData\Local\Temp\_AI3F9A.tmp\x86\RVT2013\RVT2013-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\Brendan\Desktop\Auocad\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/4/4:09:21:13 Brendan MATT-PC Install Autodesk® Revit® 2013 Failed Installation aborted, Result=1603 2013/4/4:09:21:14 Brendan MATT-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2013/4/4:09:21:17 Brendan MATT-PC PageOpen InstallCompleteDialog   2013/4/4:09:21:50 Brendan MATT-PC === Setup ended ===
2013/4/4:09:29:42 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/4/4:09:29:42 Brendan MATT-PC Launch 2013/4/4:09:30:01 Brendan MATT-PC === Setup ended ===
2013/4/4:09:29:46 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/4/4:09:29:46 Brendan MATT-PC Launch 2013/4/4:09:30:00 Brendan MATT-PC Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message: 2013/4/4:09:30:01 Brendan MATT-PC PageOpen LaunchDialog   2013/4/4:09:30:03 Brendan MATT-PC PageOpen LicenseDialog   2013/4/4:09:30:09 Brendan MATT-PC PageOpen ProductInfoDialog   2013/4/4:09:34:02 Brendan MATT-PC PageOpen ProductSelectionDialog2   2013/4/4:09:34:32 Brendan MATT-PC PageOpen FullProgressDialog   2013/4/4:09:34:32 Brendan MATT-PC Installing DirectX® Runtime: C:\Users\Brendan\Desktop\Auocad\3rdParty\DirectX\DXSETUP.exe /silent 2013/4/4:09:35:57 Brendan MATT-PC Install DirectX® Runtime Succeeded  2013/4/4:09:35:57 Brendan MATT-PC Installing FaroSDK: C:\Users\Brendan\Desktop\Auocad\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT 2013/4/4:09:36:07 Brendan MATT-PC Install FaroSDK Succeeded  2013/4/4:09:36:08 Brendan MATT-PC Installing Autodesk® Revit® 2013:  TRANSFORMS="C:\Users\Brendan\Desktop\Auocad\x86\en-us\RVT2013\RVT2013.mst;C:\Users\Brendan\AppData\Local\Temp\_AI1FAA.tmp\x86\RVT2013\RVT2013-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\Brendan\Desktop\Auocad\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/4/4:09:48:23 Brendan MATT-PC Install Autodesk® Revit® 2013 Failed Installation aborted, Result=1603 2013/4/4:09:48:24 Brendan MATT-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2013/4/4:09:48:25 Brendan MATT-PC PageOpen InstallCompleteDialog   2013/4/4:10:00:33 Brendan MATT-PC === Setup ended ===
2013/4/4:10:00:49 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/4/4:10:00:49 Brendan MATT-PC Launch 2013/4/4:10:01:07 Brendan MATT-PC === Setup ended ===
2013/4/4:10:00:49 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/4/4:10:00:49 Brendan MATT-PC Launch 2013/4/4:10:01:06 Brendan MATT-PC Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message: 2013/4/4:10:01:07 Brendan MATT-PC PageOpen LaunchDialog   2013/4/4:10:01:09 Brendan MATT-PC PageOpen LicenseDialog   2013/4/4:10:01:18 Brendan MATT-PC PageOpen ProductInfoDialog   2013/4/4:10:04:15 Brendan MATT-PC PageOpen ProductSelectionDialog2   2013/4/4:10:05:33 Brendan MATT-PC PageOpen FullProgressDialog   2013/4/4:10:05:33 Brendan MATT-PC Installing DirectX® Runtime: C:\Users\Brendan\Desktop\Auocad\3rdParty\DirectX\DXSETUP.exe /silent 2013/4/4:10:06:53 Brendan MATT-PC Install DirectX® Runtime Succeeded  2013/4/4:10:06:53 Brendan MATT-PC Installing FaroSDK: C:\Users\Brendan\Desktop\Auocad\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT 2013/4/4:10:07:02 Brendan MATT-PC Install FaroSDK Succeeded  2013/4/4:10:07:03 Brendan MATT-PC Installing Autodesk® Revit® 2013:  TRANSFORMS="C:\Users\Brendan\Desktop\Auocad\x86\en-us\RVT2013\RVT2013.mst;C:\Users\Brendan\AppData\Local\Temp\_AIACEE.tmp\x86\RVT2013\RVT2013-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\Brendan\Desktop\Auocad\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/4/4:10:17:23 Brendan MATT-PC Install Autodesk® Revit® 2013 Failed Installation aborted, Result=1603 2013/4/4:10:17:23 Brendan MATT-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2013/4/4:10:17:26 Brendan MATT-PC PageOpen InstallCompleteDialog   2013/4/4:10:28:38 Brendan MATT-PC === Setup ended ===
2013/4/4:10:38:41 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/4/4:10:38:41 Brendan MATT-PC Launch 2013/4/4:10:39:03 Brendan MATT-PC === Setup ended ===
2013/4/4:10:38:45 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/4/4:10:38:45 Brendan MATT-PC Launch 2013/4/4:10:39:02 Brendan MATT-PC Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message: 2013/4/4:10:39:03 Brendan MATT-PC PageOpen LaunchDialog   2013/4/4:10:39:10 Brendan MATT-PC PageOpen LicenseDialog   2013/4/4:10:39:17 Brendan MATT-PC PageOpen ProductInfoDialog   2013/4/4:10:41:57 Brendan MATT-PC PageOpen ProductSelectionDialog2   2013/4/4:10:42:24 Brendan MATT-PC PageOpen FullProgressDialog   2013/4/4:10:42:25 Brendan MATT-PC Installing DirectX® Runtime: C:\Users\Brendan\Desktop\Auocad\3rdParty\DirectX\DXSETUP.exe /silent 2013/4/4:10:43:37 Brendan MATT-PC Install DirectX® Runtime Succeeded  2013/4/4:10:43:37 Brendan MATT-PC Installing FaroSDK: C:\Users\Brendan\Desktop\Auocad\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT 2013/4/4:10:43:45 Brendan MATT-PC Install FaroSDK Succeeded  2013/4/4:10:43:46 Brendan MATT-PC Installing Autodesk® Revit® 2013:  TRANSFORMS="C:\Users\Brendan\Desktop\Auocad\x86\en-us\RVT2013\RVT2013.mst;C:\Users\Brendan\AppData\Local\Temp\_AI625D.tmp\x86\RVT2013\RVT2013-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\Brendan\Desktop\Auocad\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/4/4:10:55:49 Brendan MATT-PC Install Autodesk® Revit® 2013 Failed Installation aborted, Result=1603 2013/4/4:10:55:49 Brendan MATT-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2013/4/4:10:55:51 Brendan MATT-PC PageOpen InstallCompleteDialog   2013/4/4:10:55:56 Brendan MATT-PC === Setup ended ===
2013/4/4:10:56:06 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/4/4:10:56:06 Brendan MATT-PC Launch 2013/4/4:10:56:36 Brendan MATT-PC === Setup ended ===
2013/4/4:10:56:07 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/4/4:10:56:07 Brendan MATT-PC Launch 2013/4/4:10:56:35 Brendan MATT-PC Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message: 2013/4/4:10:56:36 Brendan MATT-PC PageOpen LaunchDialog   2013/4/4:10:56:38 Brendan MATT-PC PageOpen LicenseDialog   2013/4/4:10:56:45 Brendan MATT-PC PageOpen ProductInfoDialog   2013/4/4:10:59:34 Brendan MATT-PC PageOpen ProductSelectionDialog2   2013/4/4:10:59:52 Brendan MATT-PC PageOpen FullProgressDialog   2013/4/4:10:59:52 Brendan MATT-PC Installing DirectX® Runtime: C:\Users\Brendan\Desktop\Auocad\3rdParty\DirectX\DXSETUP.exe /silent 2013/4/4:11:01:03 Brendan MATT-PC Install DirectX® Runtime Succeeded  2013/4/4:11:01:03 Brendan MATT-PC Installing FaroSDK: C:\Users\Brendan\Desktop\Auocad\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT 2013/4/4:11:01:11 Brendan MATT-PC Install FaroSDK Succeeded  2013/4/4:11:01:11 Brendan MATT-PC Installing Autodesk® Revit® 2013:  TRANSFORMS="C:\Users\Brendan\Desktop\Auocad\x86\en-us\RVT2013\RVT2013.mst;C:\Users\Brendan\AppData\Local\Temp\_AI67ED.tmp\x86\RVT2013\RVT2013-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\Brendan\Desktop\Auocad\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/4/4:11:21:15 Brendan MATT-PC Install Autodesk® Revit® 2013 Failed Installation aborted, Result=1603 2013/4/4:11:21:16 Brendan MATT-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2013/4/4:11:21:18 Brendan MATT-PC PageOpen InstallCompleteDialog   2013/4/4:11:21:25 Brendan MATT-PC === Setup ended ===
2013/4/4:11:21:58 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/4/4:11:21:58 Brendan MATT-PC Launch 2013/4/4:11:22:21 Brendan MATT-PC === Setup ended ===
2013/4/4:11:21:59 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/4/4:11:21:59 Brendan MATT-PC Launch 2013/4/4:11:22:20 Brendan MATT-PC Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message: 2013/4/4:11:22:21 Brendan MATT-PC PageOpen LaunchDialog   2013/4/4:11:22:28 Brendan MATT-PC PageOpen LicenseDialog   2013/4/4:11:22:34 Brendan MATT-PC PageOpen ProductInfoDialog   2013/4/4:11:25:23 Brendan MATT-PC PageOpen ProductSelectionDialog2   2013/4/4:11:34:24 Brendan MATT-PC PageOpen FullProgressDialog   2013/4/4:11:34:24 Brendan MATT-PC Installing DirectX® Runtime: C:\Users\Brendan\Desktop\Auocad\3rdParty\DirectX\DXSETUP.exe /silent 2013/4/4:11:35:32 Brendan MATT-PC Install DirectX® Runtime Succeeded  2013/4/4:11:35:32 Brendan MATT-PC Installing FaroSDK: C:\Users\Brendan\Desktop\Auocad\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT 2013/4/4:11:35:41 Brendan MATT-PC Install FaroSDK Succeeded  2013/4/4:11:35:42 Brendan MATT-PC Installing Autodesk® Revit® 2013:  TRANSFORMS="C:\Users\Brendan\Desktop\Auocad\x86\en-us\RVT2013\RVT2013.mst;C:\Users\Brendan\AppData\Local\Temp\_AI2C66.tmp\x86\RVT2013\RVT2013-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\Brendan\Desktop\Auocad\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/4/4:11:49:36 Brendan MATT-PC Install Autodesk® Revit® 2013 Failed Installation aborted, Result=1603 2013/4/4:11:49:37 Brendan MATT-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2013/4/4:11:49:38 Brendan MATT-PC PageOpen InstallCompleteDialog   2013/4/4:11:49:44 Brendan MATT-PC === Setup ended ===
2013/4/15:11:19:19 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/4/15:11:19:19 Brendan MATT-PC Launch 2013/4/15:11:19:29 Brendan MATT-PC === Setup ended ===
2013/4/15:11:19:24 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/4/15:11:19:24 Brendan MATT-PC Launch 2013/4/15:11:19:30 Brendan MATT-PC === Setup ended ===
2013/4/15:11:19:45 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/4/15:11:19:45 Brendan MATT-PC Launch 2013/4/15:11:19:53 Brendan MATT-PC === Setup ended ===
2013/4/15:11:19:49 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/4/15:11:19:49 Brendan MATT-PC Launch 2013/4/15:11:19:54 Brendan MATT-PC === Setup ended ===
2013/4/15:11:20:07 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/4/15:11:20:07 Brendan MATT-PC Launch 2013/4/15:11:20:41 Brendan MATT-PC === Setup ended ===
2013/4/15:11:20:10 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/4/15:11:20:10 Brendan MATT-PC Launch 2013/4/15:11:20:41 Brendan MATT-PC Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message: 2013/4/15:11:20:42 Brendan MATT-PC PageOpen LaunchDialog   2013/4/15:11:20:44 Brendan MATT-PC PageOpen LicenseDialog   2013/4/15:11:21:00 Brendan MATT-PC PageOpen ProductInfoDialog   2013/4/15:11:24:50 Brendan MATT-PC PageOpen ProductSelectionDialog2   2013/4/15:11:25:11 Brendan MATT-PC PageOpen FullProgressDialog   2013/4/15:11:25:11 Brendan MATT-PC Installing DirectX® Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent 2013/4/15:11:26:43 Brendan MATT-PC Install DirectX® Runtime Succeeded  2013/4/15:11:26:43 Brendan MATT-PC Installing FaroSDK: E:\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT 2013/4/15:11:26:50 Brendan MATT-PC Install FaroSDK Succeeded  2013/4/15:11:26:53 Brendan MATT-PC Installing Autodesk® Revit® 2013:  TRANSFORMS="E:\x86\en-us\RVT2013\RVT2013.mst;C:\Users\Brendan\AppData\Local\Temp\_AI4840.tmp\x86\RVT2013\RVT2013-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="E:\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/4/15:11:40:28 Brendan MATT-PC Install Autodesk® Revit® 2013 Failed Installation aborted, Result=1603 2013/4/15:11:40:28 Brendan MATT-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2013/4/15:11:40:34 Brendan MATT-PC PageOpen InstallCompleteDialog   2013/4/15:11:45:45 Brendan MATT-PC === Setup ended ===
2013/4/15:11:48:08 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/4/15:11:48:08 Brendan MATT-PC Launch 2013/4/15:11:48:08 Brendan MATT-PC An instance of setup is already running. Only one instance of setup can run at a time.2013/4/15:11:48:10 Brendan MATT-PC === Setup ended ===
2013/4/15:11:48:01 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/4/15:11:48:01 Brendan MATT-PC Launch 2013/4/15:11:48:25 Brendan MATT-PC === Setup ended ===
2013/4/15:11:48:06 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/4/15:11:48:06 Brendan MATT-PC Launch 2013/4/15:11:48:24 Brendan MATT-PC Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message: 2013/4/15:11:48:26 Brendan MATT-PC PageOpen LaunchDialog   2013/4/15:11:48:45 Brendan MATT-PC PageOpen LicenseDialog   2013/4/15:11:48:50 Brendan MATT-PC PageOpen ProductInfoDialog   2013/4/15:11:52:50 Brendan MATT-PC PageOpen ProductSelectionDialog2   2013/4/15:11:55:37 Brendan MATT-PC PageOpen FullProgressDialog   2013/4/15:11:55:37 Brendan MATT-PC Installing DirectX® Runtime: C:\Users\Brendan\Desktop\Auocad\3rdParty\DirectX\DXSETUP.exe /silent 2013/4/15:11:56:45 Brendan MATT-PC Install DirectX® Runtime Succeeded  2013/4/15:11:56:45 Brendan MATT-PC Installing FaroSDK: C:\Users\Brendan\Desktop\Auocad\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT 2013/4/15:11:56:53 Brendan MATT-PC Install FaroSDK Succeeded  2013/4/15:11:56:54 Brendan MATT-PC Installing Autodesk® Revit® 2013:  TRANSFORMS="C:\Users\Brendan\Desktop\Auocad\x86\en-us\RVT2013\RVT2013.mst;C:\Users\Brendan\AppData\Local\Temp\_AID237.tmp\x86\RVT2013\RVT2013-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\Brendan\Desktop\Auocad\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/4/15:12:15:51 Brendan MATT-PC Install Autodesk® Revit® 2013 Failed Installation aborted, Result=1603 2013/4/15:12:15:51 Brendan MATT-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2013/4/15:12:15:52 Brendan MATT-PC PageOpen InstallCompleteDialog   2013/4/15:12:15:57 Brendan MATT-PC === Setup ended ===
2013/4/18:12:23:46 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/4/18:12:23:46 Brendan MATT-PC Launch 2013/4/18:12:24:11 Brendan MATT-PC === Setup ended ===
2013/4/18:12:23:52 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/4/18:12:23:52 Brendan MATT-PC Launch 2013/4/18:12:24:10 Brendan MATT-PC Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message: 2013/4/18:12:24:11 Brendan MATT-PC PageOpen LaunchDialog   2013/4/18:12:24:16 Brendan MATT-PC === Setup ended ===
2013/4/18:12:24:52 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/4/18:12:24:52 Brendan MATT-PC Launch 2013/4/18:12:25:02 Brendan MATT-PC === Setup ended ===
2013/4/18:12:24:53 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/4/18:12:24:53 Brendan MATT-PC Launch 2013/4/18:12:25:01 Brendan MATT-PC Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message: 2013/4/18:12:25:02 Brendan MATT-PC PageOpen LaunchDialog   2013/4/18:12:25:04 Brendan MATT-PC PageOpen LicenseDialog   2013/4/18:12:25:11 Brendan MATT-PC PageOpen ProductInfoDialog   2013/4/18:12:27:49 Brendan MATT-PC PageOpen ProductSelectionDialog2   2013/4/18:12:28:38 Brendan MATT-PC PageOpen FullProgressDialog   2013/4/18:12:28:38 Brendan MATT-PC Installing DirectX® Runtime: C:\Users\Brendan\Desktop\Auocad\3rdParty\DirectX\DXSETUP.exe /silent 2013/4/18:12:29:33 Brendan MATT-PC Install DirectX® Runtime Succeeded  2013/4/18:12:29:33 Brendan MATT-PC Installing FaroSDK: C:\Users\Brendan\Desktop\Auocad\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT 2013/4/18:12:29:43 Brendan MATT-PC Install FaroSDK Succeeded  2013/4/18:12:29:43 Brendan MATT-PC Installing Autodesk® Revit® 2013:  TRANSFORMS="C:\Users\Brendan\Desktop\Auocad\x86\en-us\RVT2013\RVT2013.mst;C:\Users\Brendan\AppData\Local\Temp\_AIAE64.tmp\x86\RVT2013\RVT2013-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\Brendan\Desktop\Auocad\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/4/18:12:30:07 Brendan MATT-PC Install Autodesk® Revit® 2013 Failed Installation aborted, Result=1603 2013/4/18:12:30:07 Brendan MATT-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2013/4/18:12:30:10 Brendan MATT-PC PageOpen InstallCompleteDialog   2013/4/18:12:34:38 Brendan MATT-PC === Setup ended ===
2013/4/18:13:40:41 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/4/18:13:40:41 Brendan MATT-PC Launch 2013/4/18:13:40:49 Brendan MATT-PC === Setup ended ===
2013/4/18:13:40:46 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/4/18:13:40:46 Brendan MATT-PC Launch 2013/4/18:13:40:51 Brendan MATT-PC === Setup ended ===
2013/4/18:13:41:11 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/4/18:13:41:11 Brendan MATT-PC Launch 2013/4/18:13:41:30 Brendan MATT-PC === Setup ended ===
2013/4/18:13:41:14 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/4/18:13:41:14 Brendan MATT-PC Launch 2013/4/18:13:41:30 Brendan MATT-PC Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message: 2013/4/18:13:41:30 Brendan MATT-PC PageOpen LaunchDialog   2013/4/18:13:41:35 Brendan MATT-PC PageOpen LicenseDialog   2013/4/18:13:41:40 Brendan MATT-PC PageOpen ProductInfoDialog   2013/4/18:13:44:18 Brendan MATT-PC PageOpen ProductSelectionDialog2   2013/4/18:13:44:24 Brendan MATT-PC PageOpen FullProgressDialog   2013/4/18:13:44:24 Brendan MATT-PC Installing Autodesk® Design Review 2013:  TRANSFORMS="C:\Users\Brendan\AppData\Local\Temp\_AI57A9.tmp\x86\en-us\Components\adr2013\SetupDesignReview2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\Brendan\Desktop\Auocad\" INSTALLDIR="C:\Program Files\Autodesk\Autodesk Design Review 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/4/18:13:44:48 Brendan MATT-PC Install Autodesk® Design Review 2013 Succeeded  2013/4/18:13:44:48 Brendan MATT-PC Installing DirectX® Runtime: C:\Users\Brendan\Desktop\Auocad\3rdParty\DirectX\DXSETUP.exe /silent 2013/4/18:13:45:53 Brendan MATT-PC Install DirectX® Runtime Succeeded  2013/4/18:13:45:53 Brendan MATT-PC Installing FaroSDK: C:\Users\Brendan\Desktop\Auocad\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT 2013/4/18:13:46:02 Brendan MATT-PC Install FaroSDK Succeeded  2013/4/18:13:46:02 Brendan MATT-PC Installing Autodesk® Revit® 2013:  TRANSFORMS="C:\Users\Brendan\Desktop\Auocad\x86\en-us\RVT2013\RVT2013.mst;C:\Users\Brendan\AppData\Local\Temp\_AI57A9.tmp\x86\RVT2013\RVT2013-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\Brendan\Desktop\Auocad\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/4/18:13:46:32 Brendan MATT-PC Install Autodesk® Revit® 2013 Failed Installation aborted, Result=1603 2013/4/18:13:46:32 Brendan MATT-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2013/4/18:13:46:38 Brendan MATT-PC Rollback Autodesk® Design Review 2013 Succeeded  2013/4/18:13:46:40 Brendan MATT-PC PageOpen InstallCompleteDialog   2013/4/18:13:46:51 Brendan MATT-PC === Setup ended ===
2013/4/18:14:36:54 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/4/18:14:36:54 Brendan MATT-PC Launch 2013/4/18:14:37:33 Brendan MATT-PC === Setup ended ===
2013/4/18:14:37:02 Brendan MATT-PC === Setup started on MATT-PC by Brendan === 2013/4/18:14:37:02 Brendan MATT-PC Launch 2013/4/18:14:37:32 Brendan MATT-PC Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message: 2013/4/18:14:37:33 Brendan MATT-PC PageOpen LaunchDialog   2013/4/18:14:37:36 Brendan MATT-PC PageOpen LicenseDialog   2013/4/18:14:37:45 Brendan MATT-PC PageOpen ProductInfoDialog   2013/4/18:14:41:44 Brendan MATT-PC PageOpen ProductSelectionDialog2   2013/4/18:14:41:57 Brendan MATT-PC PageOpen FullProgressDialog   2013/4/18:14:41:57 Brendan MATT-PC Installing Autodesk® Design Review 2013:  TRANSFORMS="C:\Users\Brendan\AppData\Local\Temp\_AIE155.tmp\x86\en-us\Components\adr2013\SetupDesignReview2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="E:\" INSTALLDIR="C:\Program Files\Autodesk\Autodesk Design Review 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/4/18:14:42:23 Brendan MATT-PC Install Autodesk® Design Review 2013 Succeeded  2013/4/18:14:42:23 Brendan MATT-PC Installing DirectX® Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent 2013/4/18:14:43:38 Brendan MATT-PC Install DirectX® Runtime Succeeded  2013/4/18:14:43:38 Brendan MATT-PC Installing FaroSDK: E:\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT 2013/4/18:14:43:46 Brendan MATT-PC Install FaroSDK Succeeded  2013/4/18:14:43:48 Brendan MATT-PC Installing Autodesk® Revit® 2013:  TRANSFORMS="E:\x86\en-us\RVT2013\RVT2013.mst;C:\Users\Brendan\AppData\Local\Temp\_AIE155.tmp\x86\RVT2013\RVT2013-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="E:\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/4/18:14:44:13 Brendan MATT-PC Install Autodesk® Revit® 2013 Failed Installation aborted, Result=1603 2013/4/18:14:44:13 Brendan MATT-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2013/4/18:14:44:23 Brendan MATT-PC Rollback Autodesk® Design Review 2013 Succeeded
1 REPLY 1
TravisNave
See my 1603 error link as a start.  Make sure you are not installing a service pack during install and install from your hard drive with local admin rights, UAC off, and anti-virus disabled.
Autodesk Forums:
Administrator Productivity
