I am attempting to install Revit 2013 and I'm receiving the following error message. I've pasted the information log as well. I don't know what to uninstall from my c drive to get this to work. PLEASE HELP!!!!
2012/12/13:13:55:56 jon emari JONEMARI-VAIO === Setup started on JONEMARI-VAIO by jon emari === 2012/12/13:13:55:56 jon emari JONEMARI-VAIO Launch 2012/12/13:13:55:56 jon emari JONEMARI-VAIO CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/Autodesk_Revit_2013_English_Win_32_64bit_w..." /SN 900-20635048 /PK 829E1 /student /skipEULA /akamai /auth /sid 2012/12/13:13:57:15 jon emari JONEMARI-VAIO === Setup ended ===
2012/12/13:13:56:08 jon emari JONEMARI-VAIO === Setup started on JONEMARI-VAIO by jon emari === 2012/12/13:13:56:08 jon emari JONEMARI-VAIO Launch 2012/12/13:13:57:04 jon emari JONEMARI-VAIO Download Play SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/SET... 2012/12/13:13:57:12 jon emari JONEMARI-VAIO Download Complete SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/SET... 2012/12/13:13:57:15 jon emari JONEMARI-VAIO PageOpen LaunchDialog 2012/12/13:13:59:27 jon emari JONEMARI-VAIO PageOpen LicenseDialog 2012/12/13:13:59:27 jon emari JONEMARI-VAIO PageOpen ProductInfoDialog 2012/12/13:13:59:27 jon emari JONEMARI-VAIO PageOpen ProductSelectionDialog2 2012/12/13:14:00:32 jon emari JONEMARI-VAIO PageOpen FullProgressDialog 2012/12/13:14:00:34 jon emari JONEMARI-VAIO Download Play VCREDIST2005X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2012/12/13:14:00:35 jon emari JONEMARI-VAIO Download Complete VCREDIST2005X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2012/12/13:14:00:35 jon emari JONEMARI-VAIO Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\JONEMA~1\AppData\Local\Temp\vcredist_x86_2005.log"" " 2012/12/13:14:00:42 jon emari JONEMARI-VAIO Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded 2012/12/13:14:00:42 jon emari JONEMARI-VAIO Download Play VCREDIST2010SP1X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2012/12/13:14:00:44 jon emari JONEMARI-VAIO Download Complete VCREDIST2010SP1X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2012/12/13:14:00:44 jon emari JONEMARI-VAIO Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart 2012/12/13:14:01:00 jon emari JONEMARI-VAIO Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded 2012/12/13:14:01:00 jon emari JONEMARI-VAIO Download Play VCREDIST2010SP1X64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2012/12/13:14:01:03 jon emari JONEMARI-VAIO Download Complete VCREDIST2010SP1X64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2012/12/13:14:01:03 jon emari JONEMARI-VAIO Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart 2012/12/13:14:01:15 jon emari JONEMARI-VAIO Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded 2012/12/13:14:01:16 jon emari JONEMARI-VAIO Download Play DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/DIR... 2012/12/13:14:01:49 jon emari JONEMARI-VAIO Download Complete DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/DIR... 2012/12/13:14:01:49 jon emari JONEMARI-VAIO Installing DirectX® Runtime: C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\DirectX\DXSETUP.exe /silent 2012/12/13:14:04:24 jon emari JONEMARI-VAIO Install DirectX® Runtime Succeeded 2012/12/13:14:04:24 jon emari JONEMARI-VAIO Download Play FaroSDK http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/Far... 2012/12/13:14:04:28 jon emari JONEMARI-VAIO Download Complete FaroSDK http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/Far... 2012/12/13:14:04:28 jon emari JONEMARI-VAIO Installing FaroSDK: C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT /NORESTART /LOG="C:\Users\JONEMA~1\AppData\Local\Temp\FaroSDK.log" 2012/12/13:14:05:13 jon emari JONEMARI-VAIO Install FaroSDK Succeeded 2012/12/13:14:05:13 jon emari JONEMARI-VAIO Download Play RVT2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/RVT... 2012/12/13:14:06:59 jon emari JONEMARI-VAIO Download Error RVT2013 <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/RVT... 2012/12/13:14:08:51 jon emari JONEMARI-VAIO Download Aborted RVT2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/RVT... 2012/12/13:14:08:51 jon emari JONEMARI-VAIO Install Autodesk® Revit® 2013 Failed Download Failed, Installation aborted, Result=1603 2012/12/13:14:08:54 jon emari JONEMARI-VAIO Rollback FaroSDK Failed Failure is ignored, Result=1619 2012/12/13:14:08:54 jon emari JONEMARI-VAIO Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2012/12/13:14:08:56 jon emari JONEMARI-VAIO Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619 2012/12/13:14:08:57 jon emari JONEMARI-VAIO Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619 2012/12/13:14:08:58 jon emari JONEMARI-VAIO Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619 2012/12/13:14:09:00 jon emari JONEMARI-VAIO PageOpen InstallCompleteDialog 2012/12/13:14:25:11 jon emari JONEMARI-VAIO === Setup ended ===
2012/12/13:14:39:47 jon emari JONEMARI-VAIO === Setup started on JONEMARI-VAIO by jon emari === 2012/12/13:14:39:47 jon emari JONEMARI-VAIO Launch 2012/12/13:14:39:47 jon emari JONEMARI-VAIO CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/Autodesk_Revit_2013_English_Win_32_64bit_w..." /SN 900-20635048 /PK 829E1 /student /skipEULA /akamai /auth /sid 2012/12/13:14:40:01 jon emari JONEMARI-VAIO === Setup ended ===
2012/12/13:14:39:59 jon emari JONEMARI-VAIO === Setup started on JONEMARI-VAIO by jon emari === 2012/12/13:14:39:59 jon emari JONEMARI-VAIO Launch 2012/12/13:14:40:00 jon emari JONEMARI-VAIO Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/SET... 2012/12/13:14:40:00 jon emari JONEMARI-VAIO PageOpen LaunchDialog 2012/12/13:14:40:50 jon emari JONEMARI-VAIO PageOpen LicenseDialog 2012/12/13:14:40:50 jon emari JONEMARI-VAIO PageOpen ProductInfoDialog 2012/12/13:14:40:50 jon emari JONEMARI-VAIO PageOpen ProductSelectionDialog2 2012/12/13:14:41:30 jon emari JONEMARI-VAIO PageOpen FullProgressDialog 2012/12/13:14:41:30 jon emari JONEMARI-VAIO Download Skipped DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/DIR... 2012/12/13:14:41:30 jon emari JONEMARI-VAIO Installing DirectX® Runtime: C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\DirectX\DXSETUP.exe /silent 2012/12/13:14:43:35 jon emari JONEMARI-VAIO Install DirectX® Runtime Succeeded 2012/12/13:14:43:36 jon emari JONEMARI-VAIO Download Skipped FaroSDK http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/Far... 2012/12/13:14:43:36 jon emari JONEMARI-VAIO Installing FaroSDK: C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT /NORESTART /LOG="C:\Users\JONEMA~1\AppData\Local\Temp\FaroSDK.log" 2012/12/13:14:43:45 jon emari JONEMARI-VAIO Install FaroSDK Succeeded 2012/12/13:14:43:46 jon emari JONEMARI-VAIO Download Play RVT2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/RVT... 2012/12/13:14:44:25 jon emari JONEMARI-VAIO Download Error RVT2013 <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/RVT... 2012/12/13:14:45:56 jon emari JONEMARI-VAIO Download Error RVT2013 <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/RVT... 2012/12/13:14:48:21 jon emari JONEMARI-VAIO Download Aborted RVT2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/RVT... 2012/12/13:14:48:21 jon emari JONEMARI-VAIO Install Autodesk® Revit® 2013 Failed Download Failed, Installation aborted, Result=1603 2012/12/13:14:48:22 jon emari JONEMARI-VAIO Rollback FaroSDK Failed Failure is ignored, Result=1619 2012/12/13:14:48:23 jon emari JONEMARI-VAIO Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2012/12/13:14:48:25 jon emari JONEMARI-VAIO PageOpen InstallCompleteDialog 2012/12/13:14:59:56 jon emari JONEMARI-VAIO === Setup ended ===
2013/1/16:10:15:36 jon emari JONEMARI-VAIO === Setup started on JONEMARI-VAIO by jon emari === 2013/1/16:10:15:36 jon emari JONEMARI-VAIO Launch 2013/1/16:10:15:36 jon emari JONEMARI-VAIO CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/Autodesk_Revit_2013_English_Win_32_64bit_w..." /SN 900-20635048 /PK 829E1 /student /skipEULA /akamai /auth /sid 2013/1/16:10:15:58 jon emari JONEMARI-VAIO === Setup ended ===
2013/1/16:11:46:07 jon emari JONEMARI-VAIO === Setup started on JONEMARI-VAIO by jon emari === 2013/1/16:11:46:07 jon emari JONEMARI-VAIO Launch 2013/1/16:11:46:07 jon emari JONEMARI-VAIO CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/Autodesk_Revit_2013_English_Win_32_64bit_w..." /SN 900-20635048 /PK 829E1 /student /skipEULA /akamai /auth /sid 2013/1/16:11:46:13 jon emari JONEMARI-VAIO === Setup ended ===
2013/1/16:11:46:09 jon emari JONEMARI-VAIO === Setup started on JONEMARI-VAIO by jon emari === 2013/1/16:11:46:09 jon emari JONEMARI-VAIO Launch 2013/1/16:11:46:11 jon emari JONEMARI-VAIO Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/SET... 2013/1/16:11:46:13 jon emari JONEMARI-VAIO PageOpen LaunchDialog 2013/1/16:11:46:19 jon emari JONEMARI-VAIO === Setup ended ===
2013/1/16:11:59:18 jon emari JONEMARI-VAIO === Setup started on JONEMARI-VAIO by jon emari === 2013/1/16:11:59:18 jon emari JONEMARI-VAIO Launch 2013/1/16:11:59:18 jon emari JONEMARI-VAIO CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/Autodesk_Revit_2013_English_Win_32_64bit_w..." /SN 900-20635048 /PK 829E1 /student /skipEULA /akamai /auth /sid 2013/1/16:11:59:31 jon emari JONEMARI-VAIO === Setup ended ===
2013/1/16:11:59:26 jon emari JONEMARI-VAIO === Setup started on JONEMARI-VAIO by jon emari === 2013/1/16:11:59:26 jon emari JONEMARI-VAIO Launch 2013/1/16:11:59:28 jon emari JONEMARI-VAIO Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/SET... 2013/1/16:11:59:31 jon emari JONEMARI-VAIO PageOpen LaunchDialog 2013/1/16:12:02:44 jon emari JONEMARI-VAIO PageOpen LicenseDialog 2013/1/16:12:02:44 jon emari JONEMARI-VAIO PageOpen ProductInfoDialog 2013/1/16:12:02:44 jon emari JONEMARI-VAIO PageOpen ProductSelectionDialog2 2013/1/16:12:03:23 jon emari JONEMARI-VAIO PageOpen FullProgressDialog 2013/1/16:12:03:23 jon emari JONEMARI-VAIO Download Skipped DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/DIR... 2013/1/16:12:03:23 jon emari JONEMARI-VAIO Installing DirectX® Runtime: C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\DirectX\DXSETUP.exe /silent 2013/1/16:12:05:27 jon emari JONEMARI-VAIO Install DirectX® Runtime Succeeded 2013/1/16:12:05:27 jon emari JONEMARI-VAIO Download Skipped FaroSDK http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/Far... 2013/1/16:12:05:27 jon emari JONEMARI-VAIO Installing FaroSDK: C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT /NORESTART /LOG="C:\Users\JONEMA~1\AppData\Local\Temp\FaroSDK.log" 2013/1/16:12:05:33 jon emari JONEMARI-VAIO Install FaroSDK Succeeded 2013/1/16:12:05:34 jon emari JONEMARI-VAIO Download Skipped RVT2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/RVT... 2013/1/16:12:05:34 jon emari JONEMARI-VAIO Installing Autodesk® Revit® 2013: TRANSFORMS="C:\Autodesk\WI\Autodesk Revit 2013\x64\en-us\RVT2013\RVT2013.mst;C:\Users\JONEMA~1\AppData\Local\Temp\_AI1535.tmp\x64\RVT2013\RVT2013-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/16:12:05:37 jon emari JONEMARI-VAIO Install Autodesk® Revit® 2013 Failed Installation aborted, Result=1618 2013/1/16:12:05:37 jon emari JONEMARI-VAIO Rollback FaroSDK Failed Failure is ignored, Result=1618 2013/1/16:12:05:37 jon emari JONEMARI-VAIO Rollback DirectX® Runtime Failed Failure is ignored, Result=1618 2013/1/16:12:05:38 jon emari JONEMARI-VAIO PageOpen InstallCompleteDialog 2013/1/16:12:08:01 jon emari JONEMARI-VAIO === Setup ended ===
2013/1/16:20:08:33 jon emari JONEMARI-VAIO === Setup started on JONEMARI-VAIO by jon emari === 2013/1/16:20:08:33 jon emari JONEMARI-VAIO Launch 2013/1/16:20:08:33 jon emari JONEMARI-VAIO CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/Autodesk_Revit_2013_English_Win_32_64bit_w..." /SN 900-20635048 /PK 829E1 /student /skipEULA /akamai /auth /sid 2013/1/16:20:08:41 jon emari JONEMARI-VAIO === Setup ended ===
2013/1/16:20:08:39 jon emari JONEMARI-VAIO === Setup started on JONEMARI-VAIO by jon emari === 2013/1/16:20:08:39 jon emari JONEMARI-VAIO Launch 2013/1/16:20:08:40 jon emari JONEMARI-VAIO Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/SET... 2013/1/16:20:08:41 jon emari JONEMARI-VAIO PageOpen LaunchDialog 2013/1/16:20:11:02 jon emari JONEMARI-VAIO PageOpen LicenseDialog 2013/1/16:20:11:02 jon emari JONEMARI-VAIO PageOpen ProductInfoDialog 2013/1/16:20:11:02 jon emari JONEMARI-VAIO PageOpen ProductSelectionDialog2 2013/1/16:20:11:22 jon emari JONEMARI-VAIO PageOpen FullProgressDialog 2013/1/16:20:11:23 jon emari JONEMARI-VAIO Download Skipped DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/DIR... 2013/1/16:20:11:23 jon emari JONEMARI-VAIO Installing DirectX® Runtime: C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\DirectX\DXSETUP.exe /silent 2013/1/16:20:13:16 jon emari JONEMARI-VAIO Install DirectX® Runtime Succeeded 2013/1/16:20:13:16 jon emari JONEMARI-VAIO Download Skipped FaroSDK http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/Far... 2013/1/16:20:13:16 jon emari JONEMARI-VAIO Installing FaroSDK: C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT /NORESTART /LOG="C:\Users\JONEMA~1\AppData\Local\Temp\FaroSDK.log" 2013/1/16:20:13:23 jon emari JONEMARI-VAIO Install FaroSDK Succeeded 2013/1/16:20:13:23 jon emari JONEMARI-VAIO Download Skipped RVT2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/RVT... 2013/1/16:20:13:23 jon emari JONEMARI-VAIO Installing Autodesk® Revit® 2013: TRANSFORMS="C:\Autodesk\WI\Autodesk Revit 2013\x64\en-us\RVT2013\RVT2013.mst;C:\Users\JONEMA~1\AppData\Local\Temp\_AI96.tmp\x64\RVT2013\RVT2013-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/16:20:13:23 jon emari JONEMARI-VAIO Install Autodesk® Revit® 2013 Failed Installation aborted, Result=1618 2013/1/16:20:13:23 jon emari JONEMARI-VAIO Rollback FaroSDK Failed Failure is ignored, Result=1618 2013/1/16:20:13:24 jon emari JONEMARI-VAIO Rollback DirectX® Runtime Failed Failure is ignored, Result=1618 2013/1/16:20:13:24 jon emari JONEMARI-VAIO PageOpen InstallCompleteDialog 2013/1/16:20:13:49 jon emari JONEMARI-VAIO === Setup ended ===
2013/1/17:13:57:40 jon emari JONEMARI-VAIO === Setup started on JONEMARI-VAIO by jon emari === 2013/1/17:13:57:40 jon emari JONEMARI-VAIO Launch 2013/1/17:13:57:40 jon emari JONEMARI-VAIO CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/Autodesk_Revit_2013_English_Win_32_64bit_w..." /SN 900-20635048 /PK 829E1 /student /skipEULA /akamai /auth /sid 2013/1/17:13:58:07 jon emari JONEMARI-VAIO === Setup ended ===
2013/1/17:13:58:00 jon emari JONEMARI-VAIO === Setup started on JONEMARI-VAIO by jon emari === 2013/1/17:13:58:00 jon emari JONEMARI-VAIO Launch 2013/1/17:13:58:03 jon emari JONEMARI-VAIO Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/SET... 2013/1/17:13:58:07 jon emari JONEMARI-VAIO PageOpen LaunchDialog 2013/1/17:13:59:27 jon emari JONEMARI-VAIO PageOpen LicenseDialog 2013/1/17:13:59:27 jon emari JONEMARI-VAIO PageOpen ProductInfoDialog 2013/1/17:13:59:27 jon emari JONEMARI-VAIO PageOpen ProductSelectionDialog2 2013/1/17:14:01:28 jon emari JONEMARI-VAIO PageOpen FullProgressDialog 2013/1/17:14:01:29 jon emari JONEMARI-VAIO Download Skipped DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/DIR... 2013/1/17:14:01:29 jon emari JONEMARI-VAIO Installing DirectX® Runtime: C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\DirectX\DXSETUP.exe /silent 2013/1/17:14:05:38 jon emari JONEMARI-VAIO Install DirectX® Runtime Succeeded 2013/1/17:14:05:39 jon emari JONEMARI-VAIO Download Skipped FaroSDK http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/Far... 2013/1/17:14:05:39 jon emari JONEMARI-VAIO Installing FaroSDK: C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT /NORESTART /LOG="C:\Users\JONEMA~1\AppData\Local\Temp\FaroSDK.log" 2013/1/17:14:05:52 jon emari JONEMARI-VAIO Install FaroSDK Succeeded 2013/1/17:14:05:52 jon emari JONEMARI-VAIO Download Skipped RVT2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/RVT... 2013/1/17:14:05:52 jon emari JONEMARI-VAIO Installing Autodesk® Revit® 2013: TRANSFORMS="C:\Autodesk\WI\Autodesk Revit 2013\x64\en-us\RVT2013\RVT2013.mst;C:\Users\JONEMA~1\AppData\Local\Temp\_AI1D53.tmp\x64\RVT2013\RVT2013-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/17:14:05:52 jon emari JONEMARI-VAIO Install Autodesk® Revit® 2013 Failed Installation aborted, Result=1618 2013/1/17:14:05:53 jon emari JONEMARI-VAIO Rollback FaroSDK Failed Failure is ignored, Result=1618 2013/1/17:14:05:53 jon emari JONEMARI-VAIO Rollback DirectX® Runtime Failed Failure is ignored, Result=1618 2013/1/17:14:05:54 jon emari JONEMARI-VAIO PageOpen InstallCompleteDialog 2013/1/17:22:00:15 jon emari JONEMARI-VAIO === Setup ended ===
2013/1/22:21:06:36 jon emari JONEMARI-VAIO === Setup started on JONEMARI-VAIO by jon emari === 2013/1/22:21:06:37 jon emari JONEMARI-VAIO Launch 2013/1/22:21:06:37 jon emari JONEMARI-VAIO CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/Autodesk_Revit_2013_English_Win_32_64bit_w..." /SN 900-20635048 /PK 829E1 /student /skipEULA /akamai /auth /sid 2013/1/22:21:07:01 jon emari JONEMARI-VAIO === Setup ended ===
2013/1/23:09:28:25 jon emari JONEMARI-VAIO === Setup started on JONEMARI-VAIO by jon emari === 2013/1/23:09:28:25 jon emari JONEMARI-VAIO Launch 2013/1/23:09:28:25 jon emari JONEMARI-VAIO CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/Autodesk_Revit_2013_English_Win_32_64bit_w..." /SN 900-20635048 /PK 829E1 /student /skipEULA /akamai /auth /sid 2013/1/23:09:28:42 jon emari JONEMARI-VAIO === Setup ended ===
2013/1/23:09:28:37 jon emari JONEMARI-VAIO === Setup started on JONEMARI-VAIO by jon emari === 2013/1/23:09:28:37 jon emari JONEMARI-VAIO Launch 2013/1/23:09:28:38 jon emari JONEMARI-VAIO Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/SET... 2013/1/23:09:28:42 jon emari JONEMARI-VAIO PageOpen LaunchDialog 2013/1/23:09:32:02 jon emari JONEMARI-VAIO PageOpen LicenseDialog 2013/1/23:09:32:03 jon emari JONEMARI-VAIO PageOpen ProductInfoDialog 2013/1/23:09:32:03 jon emari JONEMARI-VAIO PageOpen ProductSelectionDialog2 2013/1/23:09:32:26 jon emari JONEMARI-VAIO PageOpen FullProgressDialog 2013/1/23:09:32:26 jon emari JONEMARI-VAIO Download Skipped DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/DIR... 2013/1/23:09:32:26 jon emari JONEMARI-VAIO Installing DirectX® Runtime: C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\DirectX\DXSETUP.exe /silent 2013/1/23:09:34:43 jon emari JONEMARI-VAIO Install DirectX® Runtime Succeeded 2013/1/23:09:34:43 jon emari JONEMARI-VAIO Download Skipped FaroSDK http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/Far... 2013/1/23:09:34:43 jon emari JONEMARI-VAIO Installing FaroSDK: C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT /NORESTART /LOG="C:\Users\JONEMA~1\AppData\Local\Temp\FaroSDK.log" 2013/1/23:09:34:49 jon emari JONEMARI-VAIO Install FaroSDK Succeeded 2013/1/23:09:34:49 jon emari JONEMARI-VAIO Download Skipped RVT2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/RVT... 2013/1/23:09:34:50 jon emari JONEMARI-VAIO Installing Autodesk® Revit® 2013: TRANSFORMS="C:\Autodesk\WI\Autodesk Revit 2013\x64\en-us\RVT2013\RVT2013.mst;C:\Users\JONEMA~1\AppData\Local\Temp\_AI683.tmp\x64\RVT2013\RVT2013-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/23:09:34:50 jon emari JONEMARI-VAIO Install Autodesk® Revit® 2013 Failed Installation aborted, Result=1618 2013/1/23:09:34:50 jon emari JONEMARI-VAIO Rollback FaroSDK Failed Failure is ignored, Result=1618 2013/1/23:09:34:50 jon emari JONEMARI-VAIO Rollback DirectX® Runtime Failed Failure is ignored, Result=1618 2013/1/23:09:34:50 jon emari JONEMARI-VAIO PageOpen InstallCompleteDialog 2013/1/23:09:50:26 jon emari JONEMARI-VAIO === Setup ended ===
2013/1/23:11:20:32 jon emari JONEMARI-VAIO === Setup started on JONEMARI-VAIO by jon emari === 2013/1/23:11:20:32 jon emari JONEMARI-VAIO Launch 2013/1/23:11:20:32 jon emari JONEMARI-VAIO CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/Autodesk_Revit_2013_English_Win_32_64bit_w..." /SN 900-20635048 /PK 829E1 /student /skipEULA /akamai /auth /sid 2013/1/23:11:20:41 jon emari JONEMARI-VAIO === Setup ended ===
2013/1/23:18:30:25 jon emari JONEMARI-VAIO === Setup started on JONEMARI-VAIO by jon emari === 2013/1/23:18:30:25 jon emari JONEMARI-VAIO Launch 2013/1/23:18:30:25 jon emari JONEMARI-VAIO CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/Autodesk_Revit_2013_English_Win_32_64bit_w..." /SN 900-20635048 /PK 829E1 /student /skipEULA /akamai /auth /sid 2013/1/23:18:30:33 jon emari JONEMARI-VAIO === Setup ended ===
2013/1/23:18:37:00 jon emari JONEMARI-VAIO === Setup started on JONEMARI-VAIO by jon emari === 2013/1/23:18:37:00 jon emari JONEMARI-VAIO Launch 2013/1/23:18:37:00 jon emari JONEMARI-VAIO CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/Autodesk_Revit_2013_English_Win_32_64bit_w..." /SN 900-20635048 /PK 829E1 /student /skipEULA /akamai /auth /sid 2013/1/23:18:37:11 jon emari JONEMARI-VAIO === Setup ended ===
2013/1/23:18:37:08 jon emari JONEMARI-VAIO === Setup started on JONEMARI-VAIO by jon emari === 2013/1/23:18:37:08 jon emari JONEMARI-VAIO Launch 2013/1/23:18:37:09 jon emari JONEMARI-VAIO Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/SET... 2013/1/23:18:37:11 jon emari JONEMARI-VAIO PageOpen LaunchDialog 2013/1/23:18:39:45 jon emari JONEMARI-VAIO PageOpen LicenseDialog 2013/1/23:18:39:45 jon emari JONEMARI-VAIO PageOpen ProductInfoDialog 2013/1/23:18:39:45 jon emari JONEMARI-VAIO PageOpen ProductSelectionDialog2 2013/1/23:18:39:51 jon emari JONEMARI-VAIO PageOpen FullProgressDialog 2013/1/23:18:39:52 jon emari JONEMARI-VAIO Download Skipped DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/DIR... 2013/1/23:18:39:52 jon emari JONEMARI-VAIO Installing DirectX® Runtime: C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\DirectX\DXSETUP.exe /silent 2013/1/23:18:41:40 jon emari JONEMARI-VAIO Install DirectX® Runtime Succeeded 2013/1/23:18:41:40 jon emari JONEMARI-VAIO Download Skipped FaroSDK http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/Far... 2013/1/23:18:41:40 jon emari JONEMARI-VAIO Installing FaroSDK: C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT /NORESTART /LOG="C:\Users\JONEMA~1\AppData\Local\Temp\FaroSDK.log" 2013/1/23:18:41:46 jon emari JONEMARI-VAIO Install FaroSDK Succeeded 2013/1/23:18:41:46 jon emari JONEMARI-VAIO Download Skipped RVT2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/RVT... 2013/1/23:18:41:46 jon emari JONEMARI-VAIO Installing Autodesk® Revit® 2013: TRANSFORMS="C:\Autodesk\WI\Autodesk Revit 2013\x64\en-us\RVT2013\RVT2013.mst;C:\Users\JONEMA~1\AppData\Local\Temp\_AIC7D8.tmp\x64\RVT2013\RVT2013-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/23:18:41:49 jon emari JONEMARI-VAIO Install Autodesk® Revit® 2013 Failed Installation aborted, Result=1618 2013/1/23:18:41:49 jon emari JONEMARI-VAIO Rollback FaroSDK Failed Failure is ignored, Result=1618 2013/1/23:18:41:50 jon emari JONEMARI-VAIO Rollback DirectX® Runtime Failed Failure is ignored, Result=1618
Are you connected to the Internet during the install so it can complete the full download?
Yes. At first I was doing it wireless, but then I connected my ethernet cable and the same error occurred.
Hello. The failure is with your method of installation, downloading and installing at the same time. Your machine is just not linking this particular install process, so you need to download the program first, and then try to install.
Assuming you download these files completely, you should be able to install from here.
Thank you for taking part in our community!
