Installation & Licensing
Revit 2013 Installation complete. Some products failed to install" HELP
0 REPLIES 0
Message 1 of 1
833 Views, 0 Replies
I am trying to install Autodesk Building Design Suite Ultimate 2013 Education Version using the supplied USB from Autodesk.  I have made several attempts without every installing the main program that I need - Revit 2013.  I tried to accept the default program selections when I click on the install icon on the lower right corner of the Setup screen.  When I do this NOTHING is successfully installed.  After several attempts, I was able to successfully install Autocad 2013.  I opened up Autocad and finalized the activation procedure for the Suite.  After a computer restart, I then went back and tried to install only Revit 2013.
Now there are only 4 steps to the installation of Revit 2013.  While on the last step(1 of 4 remaining), a Revit icon appears on my desktop followed shortly by a "Windows Installer Message Box" stating;
The Feature you are trying to use is on a network resource that is unavailable - click OK to try again or enter an alternate path to a folder containing the installation package "RVT2013LP.msi" in the box below
The existing path in the box is;
C:\Autodesk\Autodesk_Revit_2013_English_Win_32-64bit\x64\en-us\RVT2013\
I have tried browsing to the file on the USB F: and I have also tried copying it to my desktop and selecting that location.  Neither approach works.
After I redirect to the file, installation continues and the icon disappears off of my desktop.  I then get to experience the Summary page stating "Installation Complete - Some Products Failed to Install" with a big red X next to Revit 2013.
I hope someone can help.  I need to use Revit.
Thank you
Andrea
0 REPLIES 0
Administrator Productivity
