I am trying to install Autodesk Building Design Suite Ultimate 2013 Education Version using the supplied USB from Autodesk. I have made several attempts without every installing the main program that I need - Revit 2013. I tried to accept the default program selections when I click on the install icon on the lower right corner of the Setup screen. When I do this NOTHING is successfully installed. After several attempts, I was able to successfully install Autocad 2013. I opened up Autocad and finalized the activation procedure for the Suite. After a computer restart, I then went back and tried to install only Revit 2013.
Now there are only 4 steps to the installation of Revit 2013. While on the last step(1 of 4 remaining), a Revit icon appears on my desktop followed shortly by a "Windows Installer Message Box" stating;
The Feature you are trying to use is on a network resource that is unavailable - click OK to try again or enter an alternate path to a folder containing the installation package "RVT2013LP.msi" in the box below
The existing path in the box is;
C:\Autodesk\Autodesk_Revit_2013_English_Win_32-64bit\x64\en-us\RVT2013\
I have tried browsing to the file on the USB F: and I have also tried copying it to my desktop and selecting that location. Neither approach works.
After I redirect to the file, installation continues and the icon disappears off of my desktop. I then get to experience the Summary page stating "Installation Complete - Some Products Failed to Install" with a big red X next to Revit 2013.
I hope someone can help. I need to use Revit.
Thank you
Andrea
