Installation & Licensing
Revit 2013 installation aborts with code 193
1 REPLY 1
329 Views, 1 Reply
Hi everyone,
trying to install Revit 2013. Sadly, the installation will abort with error code 193 (log file will be attached).
I´ve read something about that previous installed versions of C++ 2008 Redistributable are causing the error. I deinstalled my previous versions of the 2008 versions, but the error will not vanish.
Any hints?
1 REPLY 1
Ok, found the solution.
Install the packages manually with admin privileges. Both, 32 and 64 bit version.
Somehow, the Autodesk installer won´t use its granted admin privileges on these packages.
Administrator Productivity
