Installation & Licensing
Revit 2013 Install Hangs
9 REPLIES 9
Message 1 of 10
dannelson2000
5192 Views, 9 Replies
I am trying to install Revit 2013 on a windows 7 machine that meets all the requirements, I have updated everything, and stopped the antivirus, but the install still hangs.
I have attached the install log and would appreciate help with suggestions. Thanks.
9 REPLIES 9
Message 2 of 10
TravisNave
in reply to: dannelson2000
Have you tried just waiting it out?
Autodesk Forums:
Message 3 of 10
dannelson2000
in reply to: TravisNave
I have let it run probablly about 3 hours. I would expect that it should install within that time.
Does what you see in the log file suggest that it is still going but is just slow?
Message 4 of 10
TravisNave
I've seen it go twice as long as that sometimes.  Try letting it run overnight just as a test.  If it isn't installed in the morning, you have issues.  😄
Autodesk Forums:
Message 5 of 10
RBG-UK-CAD
Hi there,I've had this issue and this is what i did, First make sure you have internet access and that the Proxy is set correctly (If you use a proxy server try giving the machine full outbound) and try to run the install with an admin account.
Message 6 of 10
dannelson2000
I ran it over night and it was installed by morning. Phew!
Thanks for your help!
Message 7 of 10
gpktm
So the solution is what? To wait for 8 hours to install a program?
Message 8 of 10
dannelson2000
in reply to: gpktm
In my case yes.
Message 9 of 10
TravisNave
Good answer.  Smiley Very Happy
Autodesk Forums:
Message 10 of 10
well,I also has the pronlem with revit 2013.
when I click " extrusion" and finish drawing a square, it doest show any hint in the tool bar as" MODE",which has the tick meaning OK.!!
Just hope someone can help me fix.....thx a lot
Administrator Productivity
