Installation & Licensing
Member
dannelson2000
Message 1 of 10 (4,279 Views)
Revit 2013 Install Hangs
4279 Views, 9 Replies
04-21-2012 06:02 PM
I am trying to install Revit 2013 on a windows 7 machine that meets all the requirements, I have updated everything, and stopped the antivirus, but the install still hangs.
I have attached the install log and would appreciate help with suggestions. Thanks.
TravisNave
Message 2 of 10 (4,254 Views)
Re: Revit 2013 Install Hangs
04-22-2012 10:15 AM in reply to: dannelson2000
Have you tried just waiting it out?
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
Member
dannelson2000
Message 3 of 10 (4,248 Views)
04-22-2012 01:43 PM in reply to: TravisNave
I have let it run probablly about 3 hours. I would expect that it should install within that time.
Does what you see in the log file suggest that it is still going but is just slow?
TravisNave
Message 4 of 10 (4,246 Views)
04-22-2012 01:48 PM in reply to: dannelson2000
I've seen it go twice as long as that sometimes.  Try letting it run overnight just as a test.  If it isn't installed in the morning, you have issues.  :-D
Active Member
RBG-UK-CAD
Message 5 of 10 (4,215 Views)
04-23-2012 06:57 AM in reply to: dannelson2000
Hi there,I've had this issue and this is what i did, First make sure you have internet access and that the Proxy is set correctly (If you use a proxy server try giving the machine full outbound) and try to run the install with an admin account.
Member
dannelson2000
Message 6 of 10 (4,179 Views)
04-23-2012 10:19 PM in reply to: TravisNave
I ran it over night and it was installed by morning. Phew!
Thanks for your help!
Active Member
gpktm
Message 7 of 10 (4,052 Views)
04-27-2012 07:08 PM in reply to: dannelson2000
So the solution is what? To wait for 8 hours to install a program?
Member
dannelson2000
Message 8 of 10 (4,049 Views)
04-27-2012 09:37 PM in reply to: gpktm
In my case yes.
TravisNave
Message 9 of 10 (4,047 Views)
04-27-2012 09:46 PM in reply to: dannelson2000
Good answer.  :smileyvery-happy:
New Member
towngirl
Message 10 of 10 (623 Views)
revit 2013 - how to fix the tool" mode"
03-15-2014 06:44 AM in reply to: dannelson2000
well,I also has the pronlem with revit 2013.
when I click " extrusion" and finish drawing a square, it doest show any hint in the tool bar as" MODE",which has the tick meaning OK.!!
Just hope someone can help me fix.....thx a lot
