Installation & Licensing
Active Member
0 Kudos
Post 1 of 11
Revit 2013 Failed
521 Views, 10 Replies
01-24-2013 11:11 AM
Hello. I am a student and trying to install Revit (the free student version). I have tried multiple times and two things have happened. The first several times the install hung at 3 of 6 installing then the last few times it stops after 4, says it has been installed with errors and the install of Revit 2013 has failed. I have made sure there is enough room on my computer, I have preformed updates and cleaned my computer and nothing seems to be helping. I also tried donloading from the browser as well as onto the computer.
PLEASE HELP!!!!
I suggest you to check this solution, see if it's helpful for you.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
902 Kudos
Post 2 of 11
Re: Revit 2013 Failed
01-24-2013 11:18 AM in reply to: jilanadunaway
You need to provide the installation log.
And the software did not hang, so if you aborted it, you probably made it worse.  Revit has to download addtional content from the Internet. Depending on your connection, this could take hours.  So make sure you have a good Internet connection.
Active Member
0 Kudos
Post 3 of 11
01-24-2013 11:30 AM in reply to: TravisNave
I have a fast internet connection and I only aborted after 8 hours of leaving it to install the first itme. I was trying different things to make sure it wasn't something with my computer but I have no idea what I am doing.  I just tried this again and here is the installation log. Any help is greatly appreciated.
902 Kudos
Post 4 of 11
01-24-2013 11:39 AM in reply to: jilanadunaway
Error 1618 means that it thinks another installation is already in progress.  Aborting the install may have done this.  Have you tried a simple reboot?
Sometimes Revit can take over 8 hours to install.
Active Member
0 Kudos
Post 5 of 11
01-24-2013 01:30 PM in reply to: TravisNave
OK, I have re-started my computer and started the download over. It is not saying fail now it is still on Installing 3 of 6 and has been in this spot for about an hour.
Jilana
902 Kudos
Post 6 of 11
01-24-2013 01:46 PM in reply to: jilanadunaway
Good. It might take awhile so repost any new installation log if you have problems.
Active Member
0 Kudos
Post 7 of 11
01-24-2013 03:16 PM in reply to: TravisNave
OK, it is still installing. Thank you for your help. How long is a good amount of time to leave it before deciding it's not doing anything? I left it for 8 hours last night.
Active Member
0 Kudos
Post 8 of 11
01-24-2013 09:35 PM in reply to: jilanadunaway
At this point it has been 9.5 hours and nothing has happened. The installation is in the same spot. I will leave it overnight to see if anything else happens. If not I am not sure what to do next?
Product Support
30 Kudos
Post 9 of 11
01-24-2013 11:37 PM in reply to: jilanadunaway
Emily Xu
Active Member
0 Kudos
Post 10 of 11
01-25-2013 04:52 PM in reply to: emily.xu
I left my computer for over 24 hours and nothing happened. I had abort and restart my computer. I tried to add the site to my Trusted sites and it will not allow me as it says it has to be a https:// site to be added to the list. Could this be the issue? I do not know how to change the settings?
