Installation & Licensing
Revit 2013 Failed - Installation aborted
0 REPLIES 0
Message 1 of 1
447 Views, 0 Replies
Im having trouble installing REVIT 2013, here are the following errors i am recieving.
Would really appreciate it if someone could help me, really screwed for a project if i cant get revit up and running in the next couple of days!!
Thanks.
Install Autodesk® Revit® 2013 Language Pack Failed Download Failed, Installation aborted, Result=1603
2013/5/4:23:53:25 simo SIMO-PC Rollback FaroSDK Failed Failure is ignored, Result=1619
2013/5/4:23:53:25 simo SIMO-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
Here is the full log file
2013/5/4:23:10:01 simo SIMO-PC === Setup started on SIMO-PC by simo ===
2013/5/4:23:10:01 simo SIMO-PC Launch
2013/5/4:23:10:11 simo SIMO-PC Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/SET...
2013/5/4:23:10:12 simo SIMO-PC PageOpen LaunchDialog
2013/5/4:23:16:02 simo SIMO-PC PageOpen LicenseDialog
2013/5/4:23:16:02 simo SIMO-PC PageOpen ProductInfoDialog
2013/5/4:23:16:02 simo SIMO-PC PageOpen ProductSelectionDialog2
2013/5/4:23:16:28 simo SIMO-PC PageOpen FullProgressDialog
2013/5/4:23:16:28 simo SIMO-PC Download Skipped DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/DIR...
2013/5/4:23:16:28 simo SIMO-PC Installing DirectX® Runtime: C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\DirectX\DXSETUP.exe /silent
2013/5/4:23:19:09 simo SIMO-PC Install DirectX® Runtime Succeeded
2013/5/4:23:19:09 simo SIMO-PC Download Skipped FaroSDK http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/Far...
2013/5/4:23:19:09 simo SIMO-PC Installing FaroSDK: C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT /NORESTART /LOG="C:\Users\simo\AppData\Local\Temp\FaroSDK.log"
2013/5/4:23:19:40 simo SIMO-PC Install FaroSDK Succeeded
2013/5/4:23:19:40 simo SIMO-PC Download Skipped RVT2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/RVT...
2013/5/4:23:19:41 simo SIMO-PC Installing Autodesk® Revit® 2013: TRANSFORMS="C:\Autodesk\WI\Autodesk Revit 2013\x86\en-us\RVT2013\RVT2013.mst;C:\Users\simo\AppData\Local\Temp\_AI1410.tmp\x86\RVT2013\RVT2013-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/5/4:23:45:36 simo SIMO-PC Install Autodesk® Revit® 2013 Succeeded
2013/5/4:23:45:36 simo SIMO-PC Download Play RVT2013_en-us http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/RVT...
2013/5/4:23:46:21 simo SIMO-PC Download Aborted RVT2013_en-us http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/RVT...
2013/5/4:23:46:21 simo SIMO-PC Install Autodesk® Revit® 2013 Language Pack Failed Download Failed, Installation aborted, Result=1603
2013/5/4:23:53:25 simo SIMO-PC Rollback Autodesk® Revit® 2013 Succeeded
2013/5/4:23:53:27 simo SIMO-PC PageOpen InstallCompleteDialog
2013/5/4:23:55:34 simo SIMO-PC === Setup ended ===
0 REPLIES 0
Administrator Productivity
