Installation & Licensing
Revit 2013 Crashes at Splash Screen. Please Help!!
2 REPLIES 2
stevensm
1036 Views, 2 Replies
I have done numerous clean uninstalls and reinstalled revit 2013 on windows seven numerous time over the oast couple of days. No matter what I've done I can only get to the point where the program downloads and installs and then crashes at the splash screen. I am using the student version as I am a student. I have attached the latest journal which isthe same as the previous ones. Please Help!! I have tried all kinds of things such as going into regedit and task manager.....
2 REPLIES 2
aaronhai
in reply to: stevensm
TheSkala
Hello, I was having a similar problem than yours but any of the methods you could find in forums was helping. I downloaded Revit 2013 from Student Autodesk and Installed it directly from the web, also got the 2 Update packages, and was stil having the same problem. How did I solve it? Well, I am not sure if this can be applicable to everyone but I realized I never even finished the license process for Revit, when it began to fail initializing, so I had to check out the License Transfer Utility that is the one that takes the serial and the ID directly from the download link as far as I know.
After following those steps, Revit began working normally. Hope it hepls you, and once again I am not sure if this is a generic problem or just was in my case.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18221949&linkID=9240617
http://upandready.typepad.com/up_and_ready/2012/02/the-license-transfer-utility-doesnt-start.html
Best Regards,
Nicolas Ortiz Lara.
Administrator Productivity
