Installation & Licensing
Active Member
kronoskiros
Message 1 of 40 (11,744 Views)
Revit 2013 Communication Failure? Communication Faliure when executing?
11744 Views, 39 Replies
09-09-2012 10:07 AM
New Sager computer, Win 7 all updated, no virus software.
Revit 2013 downloads to default folders, c: autodesk for setup and downloads folder for exe,  but get Communication Faliure error when I run the exe.
Don't get what I'm doing wrong, not changing any folders, it should know how to install it self.  Yes, my interernet is on and working.
I have tried freshly downloading 3 times.  over 3 days incase server was wonky.  No firewall on this side.
Thank you, zowie
It seems to have resolved when I added a mail client.  It seems it needed a default mail client so it could communicate.
Perhaps this is why it didn't work on two new comptuers.
New Member
ahav
Message 2 of 40 (11,736 Views)
Re: Revit 2013 Communication Failure? Communication Faliure when executing?
09-09-2012 10:45 AM in reply to: kronoskiros
I'm having the exact same issue when trying to install 3ds Max Design 2013 or Autocad 2013.  I have a Sager 9280 laptop w/ clean install of Windows 7 Pro 64.
Active Member
kronoskiros
Message 3 of 40 (11,708 Views)
09-10-2012 10:56 AM in reply to: kronoskiros
Does anyone associated with autodesk look at this group?  Is there a better place to post a question?
philip.s
Message 4 of 40 (11,697 Views)
09-10-2012 11:13 AM in reply to: kronoskiros
Hi ahav and kronoskiros - We do indeed have a number of employees with varying backgrounds patrolling the Discussion Forums.
The last cause listed on your attached image suggests that a firewall could be blocking the necessary ports. Have you tried temporarily disabling your firewall or opening up ports 80 and 443?
Philip Schmelzer
Active Member
kronoskiros
Message 5 of 40 (11,670 Views)
09-12-2012 11:04 AM in reply to: kronoskiros
philip.s
Message 6 of 40 (11,667 Views)
09-12-2012 11:12 AM in reply to: kronoskiros
Thanks for following up and closing the loop kronoskiros!
Philip Schmelzer
Member
danl337
Message 7 of 40 (10,885 Views)
11-24-2012 10:58 PM in reply to: philip.s
I am getting this same pop up. I am using windows xp and have disabled firewall. How can I resolve this problem?
New Member
kevin.lampson
Message 8 of 40 (10,649 Views)
12-03-2012 08:03 AM in reply to: philip.s
Whats a mail client? As in.. outlook? Do i have to install that to get this installed? Im getting the communication error...
New Member
namo_rakliang
Message 9 of 40 (10,591 Views)
12-04-2012 08:54 PM in reply to: philip.s
i have open port 80 and 433 and also disable firewall but still doesnt work....How can i resolve it? can you fully amswer in a simple step structure please thanks :smileywink:
New Member
garryonapc
Message 10 of 40 (9,560 Views)
01-28-2013 05:09 PM in reply to: kronoskiros
How is installing a mail client a solution to this problem???
I have been trying over 5 days to install, I have disabled my antivirus and firewall. I have also tried the "browser download" and got a crappy lmza2 file. This problem is not exclusive to Revit either - i am having exactly the same issue with autocad 2013.
This is not good enough autodesk, Im going to try and find a torrent.
