Installation & Licensing
Revit 2012 LTU error 36
3 REPLIES 3
sons0019
376 Views, 3 Replies
Is there a limit on exporting a stand alone license? Below is the message I get when attaempting to export.
Product:
Autodesk Revit Architecture 2012
Serial Number:
Product Key:
240D1
Top of Form
Export Request Failed
The maximum number of exports for this serial number has been reached. You may not export more licenses than you have purchased.
Click the "Try Again" link to resubmit the request.
Try again
Error reference:36
Bottom of Form
3 REPLIES 3
TravisNave
in reply to: sons0019
Hard telling.  If you are just switching your license between your two computers (work and home or workstation and laptop) then you are allowed to simply activate both locations and avoid the LTU altogether.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
sons0019
in reply to: TravisNave
How can you activate both locations?
TravisNave
Just like you did the first time.  Your existing license should already be installed.  So instead, simply go to the 2nd one without the license and activate it.  If it fails, you can get one manually.
1-800-551-1490 > Option 1 (English) > Option 1 > (Stand-alone)
You will need to provide your serial number and the request code.
Autodesk Forums:
Administrator Productivity
