Installation & Licensing
REVIT 2012 installation problem exceptional problem
1 REPLY 1
calderon.destefano
2651 Views, 1 Reply
I have tried to install Revit 2012 5 times already in my computer, and I keep on having the same problem. I download the product, I click run. It runs. Then the Autodesk window appears. I click install. It goes through a thinking process and then it asks me to accept the terms and conditions. I accept. Then it asks for my serial number and product key. I write those numbers. I click next. And that window disappears and a new window stating a problem appears. I am attaching 2 images that shows the problem I faced. The problem window states:
Error signature:
- Application: Autodesk Installer
- Version: 5.0.78.0
- Error: Unhandled Exception
This error report includes the following:
- Operating System name and version
- Product name and version
- Graphics configuration driver name and version
- Applications that were loaded when the error ocurred.
- Active command when the error ocurred.
- Computer name (if enabled via the Deployment Wizard or the CAD Manager Control Utility)
The error report contains the following files:
- adsk_setup_minidump.dmp
- dmpuserinfo.xml
- dumpdata.zip
Please help me. I don't know what to try. I even brought my computer to a Office Depot to see whether it was a problem of my computer, and they looked at it and they said that my computer was fine. That the problem was with Autodesk... and I really don't know what else to do to get this program installed
Thanks!
Christelle
1 REPLY 1
Create a new user on that machine.  Give the user administrator rights.  Reboot and login as that user.  Run the installer making sure that UAC and anti-virus is disabled.  See if that works for you.
I doubt the problem is the Autodesk software as many more people would be experiencing this problem.  The high school kids at Office Depot, Geek Squad, etc. know nothing about how computers work.  That's why they work there instead of in the IT Departments of respectable companies. Smiley Very Happy
If you still have problems, consider posting the installation logs and dmp files from the crash.
Autodesk Forums:
Administrator Productivity
