Installation & Licensing
Revit 2012 installation error 1603
1 REPLY 1
809 Views, 1 Reply
I'm trying to install BDS Premium 2012 on a Windows 7 Professional system and keep getting this error message: "Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603"  I've tried uninstalling existing copies of the C++ with no sucess.  Help!
Full error log is attached.
1 REPLY 1
TravisNave
If uninstalling your Visual C++ Redistributable is not working, then install it manually from Microsoft and then modify your setup.ini to remove the prerequisite check for this.  The instance in the setup.ini is VCREDIST.
Autodesk Forums:
Administrator Productivity
