Installation & Licensing
Revit 2012 Install problem
1 REPLY 1
231 Views, 1 Reply
I have downloaded a student version of Revit MEP 2012 32/64
I am running Vista Ultimate SP2 64 bit
I have an I7 2.67GHz 18GB ram
I start the install and it fails amost intantly
It looks like its trying to install the x86 version
Ive tried a clean reboot, with nothing else running
Any clues?
Cheers Pete
1 REPLY 1
TravisNave
Your failure will be listed in the installation log file.  It's most likely a prerequisite installation that is failing. If so, remove that program from your computer first then try the installation again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
