I am trying to download the Revit 2012 Architecture program on my computer and after full install I get this message...
CRC failed in 3rdParty\DirectX\Feb2006_d3dx9_29_x64.cab
Unexpected end of archive
I have re-downloaded the software multiple times and restarted my computer and it still will not work.
Any solutions as to how I can fix this?
Solved by philip.s. Go to Solution.
It also has an error message that says "Some installation files are corrupt. Please download a fresh copy and retry the installation."
dude none of these solutions work i have a clean machine with a AMD phenom 2x 4 945 processor , 8.0 GB RA,, AMD Radeon HD 6670 Ive had the program before! then it started to crash so i deleted the program and now i cant redownload whats wong here ??? please help thanks
Hi leighton84:
Please check your inbox. I sent you a link where you can download Revoit Architecture 2012. Thanks!
i'm having the same troubles. i just cannot seem to download the autodesk revit arch version.. did you find a solution that worked???
Hi kball730,
What version are you trying to download / where are you downloading from. Please reply and we can provide a direct download.
im having this same problem can some one please send me the correct downloading link?
Hi Cory,
Just send a link via Private Message, but where were you downloading from? Did you try switching browsers and or download methods (Install Now, Download Now, Browser Download)?
i hve been trying to download revit from the education community autodesk. its showing the same error.. what should i do?
Hello Shreya,
CRC errors are typically resolved by switching browsers, turning off the firewall and antivirus software, and or using an alternative download method.
Can you please try one of the above and let us know if you're able to resolve the issue?
Hi @SafaMeral
Welcome to the Autodesk Community!
Have you tried the suggestions mentioned by Philip.S on the post above yours? Could you please try them and let us know how it goes?
Thank you!
Hi @camilo.lemos !
Philip.S was telling the truth. The problem was solved. Thank you. 🙂
I am trying install Revit 2012 again and again and only appear this message:
CRC failed in 3rdParty\DirectX\Feb2006_XACT_x64.cab
¿What's wrong? Could you give me a solution.
Thank you so much
Hello @sanrodrub and welcome to the community.
As mentioned above, CRC errors are typically resolved by switching browsers, turning off the firewall and antivirus software, and/or using an alternative download method.
Have you tried any of those yet?
