Hi!
I just downloaded and tried to install revit 2012. However, I immediately got the message, "Installation complete. Some products failed to install," and nothing was installed. Is there a solution to this problem? The "installation file log" and a screenshot of the result installation setup page is attached.
Thanks in advance
Solved by dembkod. Go to Solution.
Yes! Thank you for the log file. If you open it and search on the word “Failed” you will see you are conflicting with the Microsoft C++ redistributables on the machine.
There are many different versions and for some reason, the ones on your computer are causing the installer to fail. Just uninstall them from your Control Panel and let the installer reinstall them for you. This should take care of things.
Thank you for taking part in our community!
