Installation & Licensing
New Member
l.g.b.vanderwal
Message 1 of 8 (6,300 Views)
Revit 2012 architecture failed to install
6300 Views, 7 Replies
02-14-2012 02:25 PM
Hi!
I just downloaded and tried to install revit 2012 however i almost imeadiately get the message: Installation complete. Some products failed to install and so nothing is installed. Dont quite know what to do next! Can anyone help me?
Thanks in advance!
Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
Uninstall this product from your Control Panel > Programs and try to install your Autodesk product again.
TravisNave
Message 2 of 8 (6,299 Views)
Re: Revit 2012 architecture failed to install
02-14-2012 02:48 PM in reply to: l.g.b.vanderwal
New Member
ALombar4
Message 3 of 8 (4,988 Views)
09-19-2012 11:39 PM in reply to: TravisNave
Thank you!!!  This was the issue I was dealing with.  Uninstalling it got Revit 2012 to install with no problems.
New Member
velyn00pang
Message 4 of 8 (4,963 Views)
09-21-2012 12:44 AM in reply to: l.g.b.vanderwal
Need to delete all microsoft visual C++ before re-install the revit architecture?
TravisNave
Message 5 of 8 (4,941 Views)
09-21-2012 07:39 AM in reply to: velyn00pang
At least the offending versions, I would think.  You can always reinstall them after the fact.
New Member
alexl430034
Message 6 of 8 (3,960 Views)
01-16-2013 06:25 PM in reply to: l.g.b.vanderwal
Do I uninstall EVERYTHING (with Microsoft Visual C++)?  If I do where can i reinstall everything i just uninstalled.
TravisNave
Message 7 of 8 (3,957 Views)
01-16-2013 06:32 PM in reply to: alexl430034
You just need to uninstall the one that is failing.  The Autodesk installer will reinstall it for you or you can always get it from Microsoft or Windows Update after.
New Member
birsurang
Message 8 of 8 (161 Views)
08-11-2014 09:51 AM in reply to: TravisNave
thanks man..
