Installation & Licensing
New Member
yyyy1215
Message 1 of 2 (545 Views)
Revit 2012 architecture failed to install.SOS!!!!
545 Views, 1 Replies
03-04-2013 11:43 AM
2013/3/4:11:36:28 TINGRU YANG TINGRUYANG === Setup started on TINGRUYANG by TINGRU YANG ===
2013/3/4:11:36:28 TINGRU YANG TINGRUYANG Launch
2013/3/4:11:37:07 TINGRU YANG TINGRUYANG === Setup ended ===
2013/3/4:11:36:30 TINGRU YANG TINGRUYANG === Setup started on TINGRUYANG by TINGRU YANG ===
2013/3/4:11:36:30 TINGRU YANG TINGRUYANG Launch
2013/3/4:11:37:00 TINGRU YANG TINGRUYANG PageOpen LaunchDialog
2013/3/4:11:37:47 TINGRU YANG TINGRUYANG PageOpen LicenseDialog
2013/3/4:11:37:59 TINGRU YANG TINGRUYANG PageOpen ProductInfoDialog
2013/3/4:11:38:46 TINGRU YANG TINGRUYANG PageOpen ProductSelectionDialog2
2013/3/4:11:39:09 TINGRU YANG TINGRUYANG PageOpen FullProgressDialog
2013/3/4:11:39:09 TINGRU YANG TINGRUYANG Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/4:11:39:21 TINGRU YANG TINGRUYANG Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2013/3/4:11:39:21 TINGRU YANG TINGRUYANG Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/4:11:39:38 TINGRU YANG TINGRUYANG Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2013/3/4:11:39:38 TINGRU YANG TINGRUYANG Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/4:11:39:52 TINGRU YANG TINGRUYANG Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2013/3/4:11:39:52 TINGRU YANG TINGRUYANG Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/4:11:40:05 TINGRU YANG TINGRUYANG Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2013/3/4:11:40:05 TINGRU YANG TINGRUYANG Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\TINGRU~1\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/3/4:11:40:13 TINGRU YANG TINGRUYANG Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2013/3/4:11:40:16 TINGRU YANG TINGRUYANG Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Failed Installation aborted, Result=1618
2013/3/4:11:40:19 TINGRU YANG TINGRUYANG Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Failed Installation aborted, Result=1618
2013/3/4:11:40:22 TINGRU YANG TINGRUYANG Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Failed Installation aborted, Result=1618
2013/3/4:11:40:25 TINGRU YANG TINGRUYANG Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Failed Installation aborted, Result=1618
Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again.  If that fails, install the update directly from Microsoft then try the installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/3382347
Keep in mind that you can modify the setup.ini per the link above if the first steps fail to resolve your issue.
Good Luck!
TravisNave
Message 2 of 2 (541 Views)
Re: Revit 2012 architecture failed to install.SOS!!!!
03-04-2013 12:01 PM in reply to: yyyy1215
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
Good Luck!
