An office I just started at did not have any more copies of Revit Architcture 2011 which they currently use. They are upgrading to 2014 in a few weeks and are having me instal a trial version of 2011 until they buy the new version. I downloaded the program but when I go to install it I can only select the material library to install with the box to select to instal revit being grayed out and unselectable. Then if I try to instal the material library the installer crashes. I have tried redownoading and that des not work. The smae installer file works on other computers but does not work on the one I am using for some reason. The computer is brand new built the day I tried installing revit. Does anyone know how to fix this and get it installed? Thanks
Solved by TravisNave. Go to Solution.
Uninstall any version of DWF Viewer and/or Design Review on that machine, then reboot and try again.
