Cant get email activating my account. sign in 2191046
Solved by matthew.d. Go to Solution.
Solved by lynn_zhang. Go to Solution.
Solved by jessica.t. Go to Solution.
Hello. This is a technical forum. You should log into your account at https://accounts.autodesk.com/
You should find your information in there and a contact link under the "Support" option at the top.
If you are waiting on an email, Check your spam or try to create another account, possibly.
Thank you for taking part in our community!
Hi @2191046,
I have just activated your Education Community account and you should receive your confirmation email any minute. Please be sure to check your spam folder just in case it gets filtered there.
If you have any further troubles with your student account please contact the education team directly by filling out this problem form.
Thank you!
Hi @nikolaos.mazitzis and welcome to the Autodesk Community!
I was not able to find an Education Community account with the same email address you used to log here in the Autodesk Community. Did you register your account in the Education Community with a different email address? If so, could you please send me that email address via Private Message (click on my camilo.lemos profile name and then on Send This User a Private Message)?
Thank you
Can you activate my account for me the email wont send so im unable to activate my account
Hello!
I'm unfortunately not seeing an Education Community account with your email address in our system. As such, can you please contact the education team directly by filling out this problem form.
Hi Josh, are you trying to activate a new account with a different email address? According to our records, you already have a registered student account.
I am having the same problem, I can access the site an it's features but when I go to download a product it says " THIS ACCOUNT IS NOT ACTIVATED" and prompts me to resend an E-mail verdifaction in which I do and never recieve any.
Please help!
Hi @hernan.luzardo and welcome to the Autodesk Community!
I was not able to find an Education Community account with the same email address that you used to log in the Autodesk Community here. Can you please confirm that you used the same email address for the Education Community? If so, could you please try registering an account here again?
Thank you!
Welcome to the community, @KatlynL!
Using your email address I was able to look you up in our database and found that your account is in fact active. If you did not receive your confirmation email please contact the education team directly by filling out this form.
Thank you!
Did you by chance see @camilo.lemos's post from the previous page? I'm not sure what you're referring to, is this in response to a private message from Camilo? Thanks for any additional information you can provide! Thanks!
There is no option for users to delete their posts due to the archival nature of the community.
Your questions\posts helps others when searching for issues.
we normally reserve post removal for proprietary\sensitive information that was unintentionally posted
Hope this helps
Discussion_Admin
