Installation & Licensing
Replacing 32-bit download with 64-bit download
1 REPLY 1
174 Views, 1 Reply
Can I replace my downloaded and activated Autocad LT 2014 32-bit with a re-download and re-activating of Autocad LT 64-bit?
The program was purchased august 4. 2013 and it work very well, but I would like to upgrade my OS to 64-bit in order to handle more than 4g ram. I am often running several graphical programs at the same time.
Best regards
Niels Clauson-Kaas
1 REPLY 1
TravisNave
Welcome to the community.
You should be able to download the 64-bit version and activate it with your existing serial number without any issues.
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
