Installation & Licensing
repeated failure to install
3 REPLIES 3
dpt90
691 Views, 3 Replies
First I had Inventor 2012 installl and it worked fine, all up till now and the splash screen started and then the program did not run.
I tried all the "fixes" and nothing worked so I uninstalled it to try and re-install to which I kep getting errors and then I decided that I would try and download the 2013 version as that shouldnt have any problems.
Much to my dismay the entire thing is just messed up, for an expensive program it breaks so easily and your installer is so broken. PC game installers are smart enough to know when VC++ is already installed and skip it, big joke that Autodesk is incapable of doing it. Thankfull I am using a student license and this isnt costing me anything.
here is my logfile from Inventor 2013
2013/1/15:16:35:52	Daniel	DANIEL-PC	=== Setup started on DANIEL-PC by Daniel ===
2013/1/15:16:35:52	Daniel	DANIEL-PC	Launch
2013/1/15:16:36:08	Daniel	DANIEL-PC	Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2013/1/15:16:36:08	Daniel	DANIEL-PC	Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2013/1/15:16:36:08	Daniel	DANIEL-PC	PageOpen	LaunchDialog
2013/1/15:16:36:11	Daniel	DANIEL-PC	PageOpen	LicenseDialog
2013/1/15:16:36:20	Daniel	DANIEL-PC	PageOpen	ProductInfoDialog
2013/1/15:16:36:48	Daniel	DANIEL-PC	PageOpen	InventorFlavorSelectionDialog
2013/1/15:16:36:48	Daniel	DANIEL-PC	Inventorui==DefaultLanguage:	en-us
2013/1/15:16:36:48	Daniel	DANIEL-PC	Inventorui==InstallName:	INVENTOR
2013/1/15:16:36:48	Daniel	DANIEL-PC	Inventorui==ProductName:	Autodesk Inventor 2013
2013/1/15:16:36:48	Daniel	DANIEL-PC	Inventorui==DisplayName:	Autodesk® Inventor® 2013
2013/1/15:16:36:48	Daniel	DANIEL-PC	Inventorui==DeploymentName:
2013/1/15:16:36:48	Daniel	DANIEL-PC	Inventorui==SetupTitle:	Autodesk Inventor 2013
2013/1/15:16:36:48	Daniel	DANIEL-PC	Inventorui==ConfigTransform:
2013/1/15:16:36:48	Daniel	DANIEL-PC	Inventorui==ExeParams:
2013/1/15:16:36:48	Daniel	DANIEL-PC	Inventorui==ProductCode:	{7F4DD591-1764-0001-0000-7107D70F3DB4}
2013/1/15:16:36:48	Daniel	DANIEL-PC	Inventorui==SupportLink:
2013/1/15:16:36:48	Daniel	DANIEL-PC	Inventorui==InfotainmentLink:
2013/1/15:16:36:48	Daniel	DANIEL-PC	Inventorui==MsiFileName:	inventor.msi
2013/1/15:16:36:48	Daniel	DANIEL-PC	Inventorui==AdminImageConfigName:	AdminImagex64
2013/1/15:16:36:48	Daniel	DANIEL-PC	Inventorui==AdminImageRoot:
2013/1/15:16:36:48	Daniel	DANIEL-PC	Inventorui==GetBaseDeploymentName:
2013/1/15:16:36:48	Daniel	DANIEL-PC	Inventorui==DeploymentLocation:
2013/1/15:16:36:48	Daniel	DANIEL-PC	Inventorui==DocumentLink:	http://autodesk.com/wikihelp-inventor-install-2013-enu
2013/1/15:16:36:48	Daniel	DANIEL-PC	Inventorui==InstallDeploymentShortcut:
2013/1/15:16:36:48	Daniel	DANIEL-PC	Inventorui==ModifyDeploymentShortcut:
2013/1/15:16:36:48	Daniel	DANIEL-PC	Inventorui==SetupLockType:	2
2013/1/15:16:36:48	Daniel	DANIEL-PC	Inventorui==SetupNetworkType: 	1
2013/1/15:16:36:48	Daniel	DANIEL-PC	Inventorui==SystemLocale:	3081
2013/1/15:16:36:48	Daniel	DANIEL-PC	Inventorui==EvalMsiFilePath:	C:\Users\Daniel\AppData\Local\Temp\_AI542C.tmp\SetupRes\eval.msi
2013/1/15:16:36:48	Daniel	DANIEL-PC	Inventorui==EulaPath:	C:\Users\Daniel\AppData\Local\Temp\_AI542C.tmp\EULA
2013/1/15:16:36:48	Daniel	DANIEL-PC	Inventorui==InstallLogPath:	C:\Users\Daniel\AppData\Local\Temp\Inventor2013Install.log
2013/1/15:16:36:48	Daniel	DANIEL-PC	Inventorui==ConfigFile:	C:\Users\Daniel\AppData\Local\Temp\_AI542C.tmp\Setup.ini
2013/1/15:16:36:48	Daniel	DANIEL-PC	Inventorui==SetupPath:	C:\Users\Daniel\AppData\Local\Temp\_AI542C.tmp\
2013/1/15:16:36:48	Daniel	DANIEL-PC	Inventorui==NetworkLogPath:
2013/1/15:16:36:48	Daniel	DANIEL-PC	Inventorui==SourceRoot:	C:\Autodesk\Autodesk_Inventor_2013_English_Win_64bit\
2013/1/15:16:36:49	Daniel	DANIEL-PC	Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2013/1/15:16:36:49	Daniel	DANIEL-PC	PageOpen	ProductSelectionDialog2
2013/1/15:16:37:07	Daniel	DANIEL-PC	PageOpen	FullProgressDialog
2013/1/15:16:37:08	Daniel	DANIEL-PC	Uninstall	{8D20B4D7-3422-4099-9332-39F27E617A6F}	Failed
2013/1/15:16:37:08	Daniel	DANIEL-PC	Uninstall	{55D9E026-DCB0-46FF-B60A-68B972228CF6}	Failed
2013/1/15:16:37:08	Daniel	DANIEL-PC	Uninstall	{450063AA-643B-417C-8CF5-405BA3F4EF40}	Failed
2013/1/15:16:37:08	Daniel	DANIEL-PC	Uninstall	{02A00C13-555A-4B8A-B53B-1D02FFF5EEAF}	Failed
2013/1/15:16:37:08	Daniel	DANIEL-PC	Uninstall	{106EC844-9F5E-4B72-BB3B-1E47D274A944}	Failed
2013/1/15:16:37:08	Daniel	DANIEL-PC	Uninstall	{FACF203E-0F4D-489A-B80C-D185253C8FCB}	Failed
2013/1/15:16:37:08	Daniel	DANIEL-PC	Uninstall	{1A2948E0-9445-42BE-9D01-472952F2657F}	Failed
2013/1/15:16:37:08	Daniel	DANIEL-PC	Uninstall	{9A346205-EA92-4406-B1AB-50379DA3F057}	Failed
2013/1/15:16:37:08	Daniel	DANIEL-PC	Uninstall	{C46C3C20-039E-4D7C-869F-9C0C05D65C06}	Failed
2013/1/15:16:37:08	Daniel	DANIEL-PC	Uninstall	{577D60CB-0D5E-48D1-8850-84098AD34804}	Failed
2013/1/15:16:37:08	Daniel	DANIEL-PC	Uninstall	{0576A3D0-0000-0409-0000-491C453655D7}	Failed
2013/1/15:16:37:08	Daniel	DANIEL-PC	Uninstall	{7BDBD5BE-B02E-4FB4-8735-B9AF4FCA838F}	Failed
2013/1/15:16:37:08	Daniel	DANIEL-PC	Uninstall	{1ECD6EC8-7BB2-4CD5-A384-BAA371BC4D21}	Failed
2013/1/15:16:37:08	Daniel	DANIEL-PC	Uninstall	{4780F600-0000-0409-0000-114715ACF216}	Failed
2013/1/15:16:37:08	Daniel	DANIEL-PC	Installing Autodesk® Design Review 2013:   INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Design Review 2013\"  ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Inventor_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/1/15:16:37:45	Daniel	DANIEL-PC	Install	Autodesk® Design Review 2013	Succeeded
2013/1/15:16:37:45	Daniel	DANIEL-PC	Installing Autodesk Material Library 2013:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Inventor_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/1/15:16:38:06	Daniel	DANIEL-PC	Install	Autodesk Material Library 2013	Succeeded
2013/1/15:16:38:06	Daniel	DANIEL-PC	Installing Autodesk Material Library 2013 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Inventor_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/1/15:16:38:18	Daniel	DANIEL-PC	Install	Autodesk Material Library 2013 - Base Image Library	Succeeded
2013/1/15:16:38:18	Daniel	DANIEL-PC	Installing DirectX® Runtime: C:\Autodesk\Autodesk_Inventor_2013_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2013/1/15:16:39:27	Daniel	DANIEL-PC	Install	DirectX® Runtime	Succeeded
2013/1/15:16:39:27	Daniel	DANIEL-PC	Installing Autodesk Material Library 2013 - Low Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Inventor_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/1/15:16:40:44	Daniel	DANIEL-PC	Install	Autodesk Material Library 2013 - Low Image Library	Succeeded
2013/1/15:16:40:44	Daniel	DANIEL-PC	Installing Autodesk Cloud sync:  ADLANGUAGE=en-us ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Inventor_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/1/15:16:41:03	Daniel	DANIEL-PC	Install	Autodesk Cloud sync	Succeeded
2013/1/15:16:41:06	Daniel	DANIEL-PC	Installing Autodesk® Inventor® 2013:  TRANSFORMS="C:\Autodesk\Autodesk_Inventor_2013_English_Win_64bit\x64\en-us\Inventor\inventor.mst;C:\Users\Daniel\AppData\Local\Temp\_AI542C.tmp\x64\inventor\inventor-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Inventor_2013_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\Inventor 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/1/15:18:59:20	Daniel	DANIEL-PC	Install	Autodesk® Inventor® 2013	Failed	Installation aborted, Result=1603
2013/1/15:18:59:24	Daniel	DANIEL-PC	Rollback	Autodesk Cloud sync	Succeeded
2013/1/15:18:59:36	Daniel	DANIEL-PC	Rollback	Autodesk Material Library 2013 - Low Image Library	Succeeded
2013/1/15:18:59:36	Daniel	DANIEL-PC	Rollback	DirectX® Runtime	Failed	Failure is ignored, Result=1619
2013/1/15:18:59:49	Daniel	DANIEL-PC	Rollback	Autodesk Material Library 2013 - Base Image Library	Succeeded
2013/1/15:19:00:13	Daniel	DANIEL-PC	Rollback	Autodesk Material Library 2013	Succeeded
2013/1/15:19:00:33	Daniel	DANIEL-PC	Rollback	Autodesk® Design Review 2013	Succeeded
 Edited by
Discussion_Admin
3 REPLIES 3
dpt90
in reply to: dpt90
Can nobody help me at all?
dpt90
in reply to: dpt90
bump
dembkod
in reply to: dpt90
Dpt90,
Hello. Your issue could be a result of a few things. When you say you “tried all the fixes” – I have absolutely no idea what you mean. So I expect I may be repeating some of what you may have already tried.
You should uninstall the program through the Control Panel.
After this, run the MS Fixit uninstaller and see if the product still lists. If it does, uninstall it.
http://support.microsoft.com/mats/Program_Install_and_Uninstall\
Next, delete the Inventor program folders in these locations (they should be clearly named).
C:\ProgramData\Autodesk\
C:\Users\All Users\Autodesk\
C:\Users\**YOUR USERID**\AppData\Roaming\Autodesk\
C:\Users\**YOUR USERID**\AppData\Local\Autodesk\
After these are deleted, I would remove your C++ redistributables and remove your NET entries. Then reinstall as an admin with UAC and antivirus turned off and retest.
David Dembkoski
Product Support Specialist
Autodesk Product Support
David Dembkoski
Administrator Productivity
