If AutoCAD 2013 and Civil 3D 2013 are installed in that order, when removing just AutoCAD 2013, should the following components of the AutoCAD 2013 installation be left on the machine? Are they shared between products?
I know the FARO driver should be left.
Solved by Albert_Rius. Go to Solution.
Hi GTVic,
These are shared components that are used for most of the Autodesk applications.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
