Is it recommended to completely remove previous versions of Inventor and AutoCad prior to installing 2012?
Solved by hashim.mundol. Go to Solution.
Removing old version is not a requirement for 2012 installation.you can safely run previous versions in parall as long as you have the right license.
If you don't use it you could remove it, to keep your system clean 🙂
