I need to transfer the installation of revit 2014, from one disk in the computer, to another disk in the same computer( an SSD faster one), am not shure how to do it , whithout having problems whith the licensing, or the reinstallation. The SSD disk is the C: drive Thanks
You'll have to reinstall. The licensing will not work if you move it, even by cloning.
You probably won't see much of an improvement though, as the I/O of the hard drive is not the bottle-neck in Revit.
You can't export then import into the same computer. Reinstallation onto a different drive should stay licensed so long as the original disk is still in the system. Are you doing a replacement, format, etc?
No , no format, just the chage of drive, the actual drive in which is the program is installed, is a Western Digital green version, and when it stops spining in order to save energy, at sometimes it causes some delays or even program crashes.
If that original drive is staying then I suspect a reinstall is all you will need, assuming that drive or another drive with the original Windows installation still exists. The license will be in the ProgramData\Flexnet folder. I suspect as long as that doesn't change, you should be fine.
