My computer crashed and I had to reinstall Autocad 2010. I went thru the steps of deleting all traces of Autocad
& autodesk. Removed files from the registry. When i reinstall Autocad i get an error message that (1 Autocad was not
installed properly try installing again)-(2 you do not have sufficient rights to run autocad.)
Are you local admin on your machine?
Right-click the setup.exe and Run as Administrator.
