Installation & Licensing
Nohicom
302 Views, 4 Replies
Reinstallation Help
Previously on my home computer I installed Autodesk Inventor Professional 2015, so that I could get more work done on a project for an engineering class than what I could do in class alone. Later, I realized that the class uses the 2014 version, and the file system was incompatible between the two. I uninstalled 2015 and tried installing 2014, but it didn't install correctly. It said it installed, but I tried to find it and there was nothing there. I tried removing all files from my computer using instructions from the support section, and restarting my computer, and then reinstalling it... it didn't show up. I tried multiple times, still no luck. When I went back into the installer again after a few tries I noticed that even though I had removed all files from my computer relating to Autodesk, the installer was only installing the content libraries and nothing else because it seemed to still think everythign else was still installed. Does anybody know how to fix this and how I can install the 2014 version correctly? I would appreciate help.
4 REPLIES 4
TravisNave
in reply to: Nohicom
To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
http://support.microsoft.com/mats/Program_Install_and_Uninstall
For more information on the Autodesk KB Support article concerning the clean uninstall of Autodesk products, see this link:
http://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/How-to-perform-a-clean-un...
For all other installation problems carefully consider using the Microsoft Installer Clean Up Utility at your own risk. For more information on this program, please thoroughly read my forum post here:
http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Installer-Clean-Up-Utility-for-Add-Re...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Nohicom
in reply to: TravisNave
@TravisNave Thanks 🙂 That let it install fine, although now it's giving me the following error when I try to launch:
"The application was unable to start correctly (0xc0000142). Click OK to close the application."
What do I do now to fix it? Does it simply require a computer restart, or is the solution something else? (This may have already been answered, if so a link to the solution would be appreciated.)
TravisNave
See my signature line for that error. It's generally Adobe Acrobat or an
nVidia driver.
Autodesk Forums:
Nohicom
ok, I'll look and see if I can figure out the problem. 🙂
Administrator Productivity
