I have a user getting an "invalid installation" message when lauching. I know I can uninstall the program by itself, is there a way to reinstall the program by itself? I'd hate to have to uninstall the entire Civil 3D program to do this. I'm sure the program is in the installation folders, just would like a little help finding it.
Anything you can provide would be a great help!
Chris
Solved by christopher.bradt. Go to Solution.
Found it.
...\AdminImage\x86\en-US\Components\SSA2012\SSA Stand-Alone 2012 x86.msi
Thanks anyway.
Chris
You should be able to uninstall it from Control Panel and then just reinstall that portion of your suite during installation.
For more information on the Autodesk KB Support article concerning the clean uninstall of Autodesk products, see this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
its a separate installation
it should show up in the add/remove programs
DarrenP
