Installation & Licensing
reinstall AutoCAD LT 2009 after system crash, do I need to unregister first
1 REPLY 1
SusanSkye
740 Views, 1 Reply
This week I was forced to have a destructive reboot done on the computer running AutoCAD LT 2009, because Windows Vista had become corrupt and was malfunctioning. I need to know if I must un-register AutoCAD LT 2009 and re-register it, or if the license will work just as in a first-time installation. It is a stand-alone license for a single PC.
SusanSkye
1 REPLY 1
TravisNave
in reply to: SusanSkye
You shouldn't have any problem reactivating the software. If you do, you can get an activation code from Autodesk. This is a common mishap. 😃
Autodesk Forums:
Administrator Productivity
