I have a current activate network license w/ many Autodesk applications, and will need to rehost this license to another server. What is the process for this? I am hoping there is an easy way to to this w/ your help. Thank you. Let me know if you need any more info.
Hi
Welcome to Autodesk Community!
For the license server, you will need to regenerate a new license file according to the new server information(servername and MAC address) and configure it.
For the client, just add a system environment variable (adskflex_license_file = @servername) to point to the new license server.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Hi Yolanda,
Just to quickly explain what Emily is talking about.
On your current server you have a utility installed called LMTools. Inside of LMTools you configure where to find your licence file (.lic). You would have received this file either from your VAR or Autodesk. In this .lic file it contains the Host name and Mac address.Once you have this file and paths set up on your server you install the software on the users desktop.
Now to change a server you have to do the first part again. The steps would be the following:
Please let me know if you need any help with this and I will gladly assist you
