Installation & Licensing
Registration failed with code: 26
2 REPLIES 2
cprestre
1769 Views, 2 Replies
Hi, my name is Simon Escobar and i'm SysAdmin on a Rocks Cluster based on CentOS, we bought  Autodesk Maya and successfully installed the Network License Manager, but when we try to register the software in a compute node it says: "Registration failed with code: 26", i don't know what it means, i tried to search on forums and google but i didn't found anything, this is the command i'm using:
adlmreg -i N 657f1 657f1 2014.0.0.F XXX-XXXXXXXX /var/opt/Autodesk/Adlm/Maya2014/MayaConfig.pit
output -> Registration failed with code: 26
what's the meaning of code 26?, what i can do for fixing this issue? or any suggestion?
Thanks.
2 REPLIES 2
byron.morales
in reply to: cprestre
Below is the link to Autodesk Installation Help doc related to Maya 2015 installation via rpm utility.
http://help.autodesk.com/cloudhelp/2015/ENU/Installation-Maya/files/GUID-3E0A3A36-B1C2-4B91-994B-731...
Please note that Maya QA team has not tested installation of Maya on NFS shared space to make it shared across CentoOS cluster.  This is not supported configuration for Maya.
Byron M.
cprestre
in reply to: byron.morales
I know that, but i'm activating a local installation in a compute node and it is failing the registration step, it said "Registration failed with code: 26" I don't know what is happening, the docs don't say anything about thoose error codes.
ldd /usr/autodesk/maya2014-x64/bin/adlmreg
    linux-vdso.so.1 =>  (0x00007fff2150f000)
    libadlmPIT.so.7 => /opt/Autodesk/Adlm/R7/lib64/libadlmPIT.so.7 (0x00007f1b5bc92000)
    libadlmutil.so.7 => opt/Autodesk/Adlm/R7/lib64/libadlmutil.so.7 (0x00007f1b5ba53000)
    libz.so.1 => /lib64/libz.so.1 (0x0000003fb1400000)
    libstdc++.so.6 => /usr/lib64/libstdc++.so.6 (0x0000003fb3400000)
    libm.so.6 => /lib64/libm.so.6 (0x0000003fb1000000)
    libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x0000003fb2400000)
    libc.so.6 => /lib64/libc.so.6 (0x0000003fb0400000)
    librt.so.1 => /lib64/librt.so.1 (0x0000003fb1800000)
    libpthread.so.0 => /lib64/libpthread.so.0 (0x0000003fb0c00000)
    /lib64/ld-linux-x86-64.so.2 (0x0000003fb0000000)
PD: I'm installing Maya 2014 no 2015
Administrator Productivity
