Hi, my name is Simon Escobar and i'm SysAdmin on a Rocks Cluster based on CentOS, we bought Autodesk Maya and successfully installed the Network License Manager, but when we try to register the software in a compute node it says: "Registration failed with code: 26", i don't know what it means, i tried to search on forums and google but i didn't found anything, this is the command i'm using:
adlmreg -i N 657f1 657f1 2014.0.0.F XXX-XXXXXXXX /var/opt/Autodesk/Adlm/Maya2014/MayaConfig.pit
output -> Registration failed with code: 26
what's the meaning of code 26?, what i can do for fixing this issue? or any suggestion?
Thanks.
Below is the link to Autodesk Installation Help doc related to Maya 2015 installation via rpm utility.
http://help.autodesk.com/cloudhelp/2015/ENU/Installation-Maya/files/GUID-3E0A3A36-B1C2-4B91-994B-731...
Please note that Maya QA team has not tested installation of Maya on NFS shared space to make it shared across CentoOS cluster. This is not supported configuration for Maya.
I know that, but i'm activating a local installation in a compute node and it is failing the registration step, it said "Registration failed with code: 26" I don't know what is happening, the docs don't say anything about thoose error codes.
ldd /usr/autodesk/maya2014-x64/bin/adlmreg
linux-vdso.so.1 => (0x00007fff2150f000)
libadlmPIT.so.7 => /opt/Autodesk/Adlm/R7/lib64/libadlmPIT.so.7 (0x00007f1b5bc92000)
libadlmutil.so.7 => opt/Autodesk/Adlm/R7/lib64/libadlmutil.so.7 (0x00007f1b5ba53000)
libz.so.1 => /lib64/libz.so.1 (0x0000003fb1400000)
libstdc++.so.6 => /usr/lib64/libstdc++.so.6 (0x0000003fb3400000)
libm.so.6 => /lib64/libm.so.6 (0x0000003fb1000000)
libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x0000003fb2400000)
libc.so.6 => /lib64/libc.so.6 (0x0000003fb0400000)
librt.so.1 => /lib64/librt.so.1 (0x0000003fb1800000)
libpthread.so.0 => /lib64/libpthread.so.0 (0x0000003fb0c00000)
/lib64/ld-linux-x86-64.so.2 (0x0000003fb0000000)
PD: I'm installing Maya 2014 no 2015
