Hello, I'm student and I'cant activate may autocad 2016. When I have open autocad and have click next toactivate I have this error Registration-Activation Error (0015.111)
I received my activation code via mail but didn't work.
Thaks for supp
Solved by Otto. Go to Solution.
Hello Otto,
I have the same problem with the Error (0015.111) and i tried to get the article posted on your reply. Unfortunately, the page has been moved or deleted.
Can you perhaps offer me another solution?
Welcome to the Autodesk User's Community..
Autodesk Product and Version? Type of license? Are you a student?
Mark Lancaster
& Autodesk Services MarketPlace Provider
i have activate autodesk inventor professional this error occur at activation time
Registration-Activation Error (0015.1)11 plz give me proper solution
I followed the instructions on the article posted, but when I reattempt the activation I still get the same error message. I have a yearly subscription for single user/computer license for AutoCAD 2015. One problem may be that I was never able to find a file under
Please help, in the middle of a professional project with upcoming deadlines, and the current license runs out in 6 days.
Hello @emmyweldon,
Welcome to the Community.
Have you already made the files visible on your machine, as indicated in the same Autodesk Solution: Reset Activation for an Autodesk Product -- Stand-Alone License with Single-User Access?
Thanks for the confirmation. In that case, it may be best to reach out to our support team here so they could further investigate on this issue: http://autode.sk/2kCxfwA
Hi @emmyweldon,
Have you already tried submitting your request to our support team through the contact support form? Is your license already activated or are you still having issues with it?
Hello @dnyansh321,
Welcome to the Autodesk Community!
Please check out the following solutions:
Activation Error 0015.111 when trying to activate your Autodesk license.
If this does not help, please contact our Registration & Activation team, so they can troubleshoot further. Go to Contact Support - Activation & Registration, then ask AVA (our Virtual Agent). If AVA can't help, it will redirect you to the Registration & Activation team, which you can contact via Chat or E-mail.
Hello @dnyansh321,
Did you get a chance to check out my previous response ? Were you able to troubleshoot the activation error or did you get in touch with our Registration & Activation team ? If my previous post helped, please feel free to mark it as 'Accepted Solution'.
Hello all!
I am having the same issues and I did follow these steps but I keep getting the reactivation screen every time I close Maya and keep getting the Error (0015.111) and I only have 3 days left to use Maya 2016. I rather keep using this version since I got really use to it and I would hate to switch to a newer version and have issues with it when it comes to compatibility with my PC hardware.
Any suggestions are welcomed!
Thank you in advance for your time in this matter!
~Jose
UPDATE:
I also tried the " Reactivate Expired Home Use License" process and preformed the steps but unfortunately it still doesn't work.
