In my schools account country set to India, when my university is in Russia, and i can't change the country (in select field), but in regions of india (select field) i found Russia.
When i attempt to register my serial number via registeronce service, i got error:
Can not register the software in the following countries : Russian Federation. (Error 7)
Solved by dembkod. Go to Solution.
Hello. Looks like your post was escalated. Someone should be in touch with you if they have not already.
Thank you for taking part in our community!
Hello, I´m from argentina and I get the same error when I trying to register my Network license Manager.
The message that i get says: "El producto no se puede registrar en India. (Error 7)"
What should I do?
Hello. You should run through the activation link. There are instructions on a form there.
Hello, Thanks for your reply.
I don´t see where is the option that solve this error.
What I´m doing is follow the steps in this video in order to activate my server as a Network License MAnager
https://www.youtube.com/watch?v=Tdfe1AkZh88&feature=youtu.be
but I´m stuck in this step
