(Customer Support):
Would you be able to help me on the following.
Attached you send me a new rehost license and we actually need the following request from out IT department.
- Will it be possible to regenerate the license files without ANY SUPERSEDE attributes?
This will be for all the attached licenses that you rehosted for AMD A DN 3422. We will need all SUPERSEDE to be omitted due to fact that we have consolidated all of A DN license for AMD into 1 server and we are using current versions as past versions to recreate and fix issues for end customers. We will also be requesting 2015 licenses for the same server and I will also need to ensure that there is no entry for SUPERSEDE attributes for the same reason.
Let me know if you can do this for AMD AD N usage.
I will have a similar request for the other licenses already generated for other countries for AMD A DN usage.. Will you be able to help me on these requests? J_
Thank you for your time on this Emily or customer support!
Yolanda Ruiz
don't post license file info or serial number info on a public website
i will have the admin delete your attachment
DarrenP
you need to contact your reseller or autodesk to do this
You can use the online method to activate your license here:
http://knowledge.autodesk.com/contactus or www.autodesk.com/register
for the contact us page use these steps to fill out a form
1. Activation & Registration
2. Activating a Product
3. Activation Codes & Request Codes
4. I still need help
5. Ask for assistance at the bottom
Or you can can call Autodesk Product Registration and Authorization:
1-800-551-1490 > Option 1 (English) > Option 2 > (network)
Asia / Pacific: 65.6735.5688
Europe / Middle East / Asia: 41.32.723.9595
You will need to provide your serial number and MAC Address, Server name
DarrenP
