Installation & Licensing
Regarding licensing of mudbox
1 REPLY 1
193 Views, 1 Reply
hi
i am looking to download mudbox
i would like to know if i download mudbox student version and create my work and then buy a desktop subscription of mudbox to publish my work
is that legal?
thanks
1 REPLY 1
TravisNave
This is a common question and a very good one.
Unfortunately, the answer is no.  The EULA is very specific in stating that the work done for educational work is strctly for instructional purposes only.  You cannot use any work produced in the educational version in the commercial version.  Even so, you absolutely do not want to do this anyway because the educational stamp will effectively poison commercial work and anyone viewing or sharing the work with you will also be poisoned as educational work.  You will, unfortunately, have to redo the work. However, at least you will know how to do it more efficiently.  🙂
It's always good to ask, because many have tried without checking first and are then faced with the greater problem of their entire work being lost to this issue.  Good luck!
http://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Education-Community-Licen...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
