Jerry,
What errors will result with the workstation OS when the 10 concurrent user
limit is reached?
"jerry milana (Autodesk Consulting)" wrote in message
news:4238e59b$1_2@newsprd01...
> If this is 2004 or 2005 based product you can keep the Admin Image and use
> the Network Install Wizard (NIW) to modify the image and create a new
> deployment with the single server information. As for stations already
> installed, you can simply replace the LICPATH.LIC file with the single
> server version that will appear on workstations installed using the new
> deployment. Simply deploy the new deployment to a workstation, copy its
> LICPATH.LIC and use it to replace the file in all existing deployed
> workstations.
> Keep in mind that even running a single server model you can run into
> problems running the license manager on workstation operating systems.
> This is because they impose a 10 concurrent connection limit which can
> cause license denial and/or loss depending on activity on the system
> running the license manager.
> Jerry Milana,
> Autodesk Consulting
> "Garrak" wrote in message
> news:4238ba28$1_1@newsprd01...
>> Thank you Travis.
>> "TravisNave" wrote in message
>> news:18633187.1111008909232.JavaMail.jive@jiveforum1.autodesk.com...
>>> Sounds like a mess. I definitely recommend that you just start over.
>>> Any image files created will likely point to the old server name, MAC
>>> address, etc. and will cause more problems than it is worth. Building a
>>> new image takes less time than trying to fix existing ones anyway. Good
>>> luck with that!
