In article <5175961@discussion.autodesk.com>, ewells <> says...
> Is there any way to get this to work on separate subnets?
> If not, that leaves the distributed server as our only option, and that isn=
> 't very practical for our environment.
> We have a main office with roughly 30-40 CAD users, although normal usage s=
> tays between 20-30.
> However, we have 11 CAD users in our branch office.
> We have 42 licenses total so I would have to split it up 31 and 11 and this=
> could potentially cause problems.
> There is of course the option to purchase more licenses to cover the overhe=
> ad, but that isn't really the goal.
> The main reason we need to have the licenses available on separate servers =
> is in case our WAN link goes down, which does happen more often than we wou=
> ld like. This is also south florida, so we're approaching hurricane season =
> and that hit us pretty hard last year causing a lot of downtime and lost bi=
> lling.
> Is there any other way to set this up other than splitting licenses?
Redundant servers only work for a location that can access any 2 of the
3 servers. Any location that can't access at least 2 of the servers will
go down.
I'd recommemnd a distributed setup. That's what we have here. If the
link goes down, each location is limited to only the licenses on their
server.
However if the link is up, you can have the clients configured to search
multiple servers. We only have 6 licenses on our Texas server. If those
are all used up and a 7th user in texas tries to start AutoCAD, it get's
pulled through the netwrok from our Minnesota office. Works the other
way to. As long as the connecxtion is up between the two offices, the
total number of licenses in both locations are completely available at
either location.
We even have the clients configured to look for a 3rd, non-existent
server so if one of our servers goes down, we can get a different server
up and running quickly. The Network License Activation Utility will then
let us get a new license bound to the new servers. LAst time our server
guys reorganized our servers and forced us to move out license server,
we had it moved in less than 1/2 hour.
Darren J. Young
CAD/CAM Systems Developer
Cold Spring Granite Company
202 South Third Avenue
Cold Spring, Minnesota 56320
Email: dyoung@coldspringgranite.com
