Installation & Licensing
Active Member
sandeep_vaal
Message 1 of 5 (211 Views)
RealDWG 2014 installation on non OS drive?
211 Views, 4 Replies
01-30-2014 03:22 AM
I have 100 GB of SSD as primary drive and I don't want to install RealDWG on C: which is already on low disk space. So tried to install it on D: by changing the path during installation but installer always installs it on C:
Is there any way to install the toolkit on D:? I am on Win 8.1
Sandeep.
pendean
Message 2 of 5 (193 Views)
Re: RealDWG 2014 installation on non OS drive?
01-30-2014 05:47 AM in reply to: sandeep_vaal
A large portion of the application wants to be on the primary OS C: drive
I would suggest you move other items off that HD instead.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Active Member
sandeep_vaal
Message 3 of 5 (190 Views)
01-30-2014 06:17 AM in reply to: sandeep_vaal
But if RealDWG needs to be on the C: then what is the use of giving option of choosing the installation directory during installation?
TravisNave
Message 4 of 5 (182 Views)
01-30-2014 07:36 AM in reply to: sandeep_vaal
Please understand that some parts of the installation files are necessary to be installed on the root system drive. Shortcuts, registry settings, and profile customizations are all examples of this. However, you may be able to make some system changes that will allow you to install your Autodesk product and avoid this error. Please review my KB article for more information:
http://forums.autodesk.com/t5/Installation-Licensing/Out-of-disk-space-during-installation-to-anothe...
Good Luck!
Active Member
sandeep_vaal
Message 5 of 5 (168 Views)
01-30-2014 09:23 PM in reply to: sandeep_vaal
I totally agree on your point. If it is required that RealDWG toolkit to be on system drive only then there should not be option of choosing the installation directory during setup.
