Installation & Licensing
Re-installing Bldg Design Suite Premium 2013
7 REPLIES 7
Message 1 of 8
tstewart
501 Views, 7 Replies
The Revit software will not launch. All other software in the Bldg. Design Suite launches, so what should I do to launch Revit from the Bldg. Design Suite 2013?
Tags (1)
7 REPLIES 7
Message 2 of 8
asburyj
in reply to: tstewart
Hi Tstewart,
Are you getting an error message of any kind when trying to launch Revit? Usually when revit won't launch when other software does I have found the problem to be video card related. Try updating your video drive to the latest available. In other cases the settings of "Switchable" grapics cards may need to be changed. See details below.
http://upandready.typepad.com/up_and_ready/2013/08/fatal-error-autocad-architecture-2014-2012-geforc...
Jeffry Asbury
Message 3 of 8
dembkod
tstewart,
Hello. If updating your graphics does not help, look at your windows Event Viewer to see if any messages display around your startup time. They may point to a failing module. It may ultimately be worth uninstalling and reinstalling, but you should only need to focus on the one program as opposed to eth whole suite..
Thank you for taking part in our community!
David Dembkoski
Message 4 of 8
tstewart
Another note - the software was installed and worked previously with no issues. It stopped launching, so I uninstalled and re-installed the suite.
Message 5 of 8
tstewart
in reply to: dembkod
The suite worked previously and recently (last 2 days) stopped launching Revit, so I uninstalled and re-installed. Now the short will no longer work properly.
Message 6 of 8
asburyj
Did you try a windows system restore to a time when it was working properly?
http://windows.microsoft.com/en-us/windows7/products/features/system-restore
Jeffry Asbury
Message 7 of 8
tstewart
in reply to: asburyj
AsburyJ:
The video card is the latest (no updates available) and all programs loaded and launched except Revit.
TS
Message 8 of 8
asburyj
Windows system restore would be my next suggestion. Since we aren't sure what change on the system lead to the problelm that would be the easiest thing to try to solve it.
Jeffry Asbury
Administrator Productivity
